Question about Kenmore Refrigerators
How do i remove the ice maker for sears refrigerator model # 106.56832604
  • 10 Answers
SOURCE: GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Posted on Jan 25, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
duby1990
  • 367 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
freetek
  • 5568 Answers
SOURCE: amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Posted on Jan 09, 2009
SOURCE: kenmore refrigerator model 106, 2doors, ice forms
I had the same problem and discovered that the water control valve was not shutting off completely between cycles. The water seeping through the valve was freezing in the water inlet tube. I replaced the water control valve for the icemaker and solved the problem.
Posted on Mar 02, 2009
How can I remove the ice tray to ensure no cubes stuck, causing overflow?
Hello Michael;
My name is Peter. I am a retired field service refrigeration technician.
If you had a stuck cube your ice maker would not cycle.
You have a hole in your ice maker mold. This happens.
Now you can get a new mold for about $70.00, or you can go on line and get a new ice maker for about $40.00. Locally at a Sears store it will cost you about $110.00 for a new ice maker.
On the upper wall of your fresh food section is a label with your model number. Go into the following web site, plug in your model number, go into google with your model number and get your ice maker.
I will walk you through the installation. It is not that hard. Water Filters Lawn Garden Appliance Parts
Jan 15, 2016 | Frigidaire Refrigerators
How can I get my Kenmore Refrigerator Model 501-7835# Ice maker to work. Stopped working.
Perhaps you can call your local Sear store and ask them what course of action you should follow.
Someone will need to take the refrigerator ice maker all apart and find the part that is broken or out of adjustment.
God bless your efforts.
Jan 08, 2016 | Kenmore Refrigerators
The icemaker has stopped making ice and the reset function no longer works.
Hello;
Your ice maker has a control board, which I suspect is bad. This happens.
You did not provide a refrigerator model number which is located on a label on the inside liner wall of your fresh food section, so I do not know what you have.
I have a friend who called Sears Home Services for his ice maker. Sears charge him $440.00.
I have customer, same ice maker and problem. I charged him, $35.00 for the same ice maker and $30.00 to install.
Depending on the ice maker you may be able to install it yourself.
I need your refrigerator model number to help you.
Peter
Nov 30, 2015 | Refrigerators
Jd-21 ice maker filters?
Take up this issue with Sears
Jun 30, 2013 | Refrigerators
I need the part # for the icemaker ordered
Now here is the confusing part. If your model number is a GE PDS22LBN the Ice Maker would be part number WR30X10039 for the model number posted above your post. If you have sears model number for the refrigerator it will be like 312.235698 for example. Confirm the model number of the refrigerator and I can tell you the correct Ice Maker part number. Thanks Sea Breeze
Feb 18, 2010 | GE PDS22LBN Bottom Freezer French Door...
Not producing ice
There are several possibilities. The dual water control valve is defective going to the ice maker, defective ice maker thermostat; frozen water fill tube leading to the ice maker is blocked with ice. You can see if ice maker is working by filling it with tap water and waiting to see if it dumps. If it does not empty the icemaker of the ice I would think ice maker thermostat. If it dumps ice and does not refill I would say you need a new dual water control valve. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Jun 11, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker isnt making ice
Be patient.
See if you still have this problem tomorrow.
Mar 31, 2009 | Kenmore Refrigerators
My sears refrigerator has an ice maker that will not shut off
You will have to remove the icemaker from the freezer so you can see if the plastic is broken that holds the arm in position.
Jan 30, 2009 | Kenmore 55693 Side by Side Refrigerator
Ice maker leaking
yes go to sears parts center and buy the ice maker part # 4317943 thats if the ice maker is in line is leaking because the mold inside is peeling off due to the wtr being to hard repl ice maker is realy easy loosen screws remove harness and repl new one that is all you might not need all parts in box
Oct 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
