Question about Whirlpool Duet GHW9150P Front Load Washer
All of a sudden my machine is jumping during the washing cycle. The washer is stopping and when restarted it continues to jump and there is water remaining on the clothes. I have checked that the machine is leveled and have not had this problem before so I'm unsure what to do
    Genius:
  • Whirlpool Master
  • 1,474 Answers
Check filter clean / pumping ok
Posted on Oct 02, 2009
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
My washer stops before the rinse cycle starts, what is the problem? I have restart the washer and when it finishes washing, in between the wash and rinse cycle, it will stop.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 27, 2010 | Kenmore Washing Machines
My washing machine suddenly refused to continue its cycle from the washing to draining and rinsing. I have a washing machine full of water.
Apr 30, 2010 | Kenmore Washing Machines
Washer will not drain
FYI: The lid must be closed for spin on older washer. It must be closed for wash and spin on newer ones. The lid has a striker in it that pushes against the lid switch arm. This switch allows for spin IF the lid is closed. The switch may have failed. Mechanically the striker may be broken or the actuator arm may be broken. The end that the harness plugs into has 3 holes. As you can see above the lid switch has 3 wires. 2 live wires and one green ground. You can jump the washer out using a horseshoe shaped wire or equivilent. Newer models have the ground wire on one end. Not good! Look for that before attempting to jump it out. At any rate their are 3 wires. One of them is always green and always mounted to the frame. The other 2 are live. You can jump them to magically make that puppy spin and pump. Not recommended to leave it that way. For testing purposes only. Some repair pix with manuals.
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
During rinse cycle, washer just stopped, and won't continue rinsing/drain/finish
Have you tried restarting the cycle? If so, does it stop at the same exact place in the rinse cycle? If so, the issue is most likely the timer mechanism (cycle control) that needs replacing.
If it doesn't stop at the same place, it may be a flaky lid switch.
Jul 09, 2009 | Washing Machines
Washer fills with water, starts it's cycle, goes through aggitate cycle, then stops timer continues a short time after to next cycle then stops, timer has been replaced and still doing the same thing
when it stops it wants to drain but your lid switch is not completing the curcit to the motor thats where i would go.you can jump it but only to test .because people can get hurt if not in use.tom
Jan 02, 2009 | Washing Machines
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
121 people viewed this question
Dan Webster
Dan Webster
Sal De
