Question about Maxtor Hard Drive
My hard drive is 40 GB. I just format the C drive for installation after finished the install I can't find others d and E drive.
  • 51 Answers
Right click on my computer-->mangment--> hard drive see if you can find 2 pattitions there. right click on any of the partition click on change drive letter and path change drive latter as d or e and clikc on apply ok
now you should be able to see your d or e drive in your computer
if you can not see drive partition in computer mangment section check size of your c drive if its 40 gb that means u formated all drives if you did not formated all drive you should be able to see drive in above method
Posted on Oct 02, 2009
Maxtor 32049h2 20.4 GB setup disk for windows 2000
After installing the hard drive in the computer then boot up with the Windows 2000 installation CD. Proceed with installing Windows. delete the existing partition , create a new partition, then format the hard disk in NTFS file format, follow the instruction to complete the installation.
You will also need the product installation code to complete the installation and you will need to activate the Windows license by the Internet or by phone. You will also need to install the motherboard device drivers.
Mar 14, 2013 | Maxtor DiamondMax VL 40 (32049H2) 20.4 GB...
..pls teach me how to
You need to purchase Windows Vista, once you have the disc with you, then you can start the Widnows installation process. during the process you can choose to format your hard drive and install Windows.
Feb 28, 2011 | IBM TravelStar 40GN 40 GB Hard Drive
Can i reformat a xbox 360 seagate harddrive to windows xp??
Yes, your can format the hard drive and install Windows this drive
If you have the Windows XP disk it will partition the drive also
The drive must be fully formatted to work properly.
Sep 23, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
Samsung40 gb harddisk unable to format (SP0411N). But i can read old data. I cant delete anything. cannot delete partition also
Try formatting / partitioning the drive with windows xp setup / installation cd. If you are trying to format or delete partition in windows and its your c: drive you will not be able to do that.
Jul 30, 2009 | Samsung (SP0411N) 40 GB Hard Drive
I've XP Pro installed on Seagate IDE 80G hard drive about 4 years ago. 4 days ago, when I boot up and it shows the Windows\system32\Config\system is missing. I tried to reinstall XP without format but was...
you will need to repartition the 40gb drive and set the partion active once again for the computer to be able to utilise the disc appropriately.if it has an OS on it i would recommend a full low level format and then using disc management set it active etc.
if this answers your query please rate my answer accordingly
regards
Apr 05, 2009 | DFI /LAN PARTY NFORCE4 ULTRA-D/...
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk is not responding while installing os
1st plug any hard disk of urs and get a bootebel cd u can say not the xp 1 but u can find old cds like windows 98 or milenium and boot it..after sellect the cd rom support aplication..wen loaded right fdisk select yes and yes..after that delet dos or any existing partitions and restart do the sam thing again but this tim make dos partition wen ur finish restart and go in again but wen loaded on a:\ wright format C: and accept..after format is finished retstart but this time boot frome windows xp or the operation system disk u want 2 install..and folow the instruction..and if i didnt work after u do all that u go 2 ms dos and make a scandisk for c after u format u can see all comands in a:\dir , thats all and 4 the other hard drive u dont need 2 do the same just after u install widows u plug it and go 2 cotrol panell in administrative tools and select the icon that have a pc signe and after that frome the second option u select the 3 and u see ur second hard disk format it and scan it and evry thing will be just fine........
Feb 04, 2008 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Hardrive Partition Is corrupt
As i review your explaination, there might be a problem in your hard drive. There so many problems i encountered in the hard drive i encountered like that. However, some problems can be fix using your solution and the other can be fix by replacing the BIOS Battery, and sometime the error in the hardrive is cause by a memory fault. If you are sure that the memory, motherboard, and the bios battery is good and working properly. I recommend you to replace your hard drive that the inconsistency problem will be fined.
Please do testing of your hard drive by connecting it to the other system.
Feb 01, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Maxtor Hard Drive Logo
44 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
