Question about Cell Phones
Phone was dropped
Only about a month old, no scratches but phone was dropped, only works on speaker phone and screen fades out sometimes but is still usable!
  • 277 Answers
Hai u told that u have dropped ur mobile so u must go to a service centre only becasue it is technical fault
thanks
Posted on Oct 02, 2009
Samsung e2152 display light problem
see the instruction and fix it. God bless you
Instruction o 1
Try a scratch-remover product. These are available online and in retail locations. Apply a small amount of the cream to the screen, then rub it in until the scratches fade away.
o 2
Apply pressure to the cell phone screen. Stuck pixels are another problem that can occur on a cell phone screen. They'll create discoloration in different areas of the phone. To fix this problem, rub at the discolored areas with a pen cap to disperse them on the screen.
o 3
Fill any cracks or scratches with a small amount of toothpaste.
o 4
Replace the cell phone screen. If the crack is severe, this may be your only option. You can search for your phone model and purchase a new screen through online stores. To make the replacement, use a screwdriver to pop off the old screen, then snap the new one into place. The process may vary depending on the model. When in doubt, take the phone to a cell phone repair shop to make the switch.
Jul 12, 2013 | Cell Phones
Will anyone purchase a tv with a cracked screen for the inner parts?
not likely as if set was on or powered on later there may not be any usable parts---consider listing it on EBAY?
May 13, 2012 | Samsung PN51D430A3DXZA - PN51D430 51 720p...
Nothing is displaying just white screen for last three days.Even before to that the display was not good i mean screen jumbling for model w395
  1. Try a scratch-remover product. These are available online and in retail locations. Apply a small amount of the cream to the screen, then rub it in until the scratches fade away.
  2. Apply pressure to the cell phone screen. Stuck pixels are another problem that can occur on a cell phone screen. They'll create discoloration in different areas of the phone. To fix this problem, rub at the discolored areas with a pen cap to disperse them on the screen.
  3. Fill any cracks or scratches with a small amount of toothpaste.
  4. Replace the cell phone screen. If the crack is severe, this may be your only option. You can search for your phone model and purchase a new screen through online stores. To make the replacement, use a screwdriver to pop off the old screen, then snap the new one into place. The process may vary depending on the model. When in doubt, take the phone to a cell phone repair shop to make the switch.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jan 17, 2011 | Cell Phones
Hey , My Motorola Rival screen is just all white. I can hear it ring and stuff but I cant read the messages. Ive tried taking out the battery, charging it, and nothing works. The phones not even 3 months...
There is a cable that conects the two sides of the phone... refered to as the flex cable when this goes bad it will cause display and sometimes speaker issues, your phone is still under warrenty take it back into your office to have it repaired. there is no quick fix to that problem.
Nov 20, 2010 | Motorola Mobility Rival A455 Cell Phone
Samsung impression touch screen just stopped working. Phone was not dropped nor is it wet.
I have the same issue! Mine just stopped working today and has never been wet or dropped. It's only 7 months old. NOT cool! I am unable to use the phone at all!
Jul 02, 2010 | Cell Phones
The lcd tv (lg 42LG5000) which is now about 15 months old has developed a fault which is intermittent some times when first switched on sometimes after half an hour an hour the left side of the screen...
The backlight inverter is dropping out, on the older lgs the backlight inverter is separate from the power supply, if this is the case you can only obtain it with a new panel.
otherwise the newer lgs have the inverter built on the power supply.
in this case you can replace the entire power board.
May 20, 2010 | Televison & Video
About 8 months old...one channel does not work...I've tried speakers and headset, one channel silent on both... we've had lightening storms, I'm on a surge protector, is it a fuse or a button I need to...
Did problem happen suddenly, or did the sound fade out slowly over time. Either way, this is not a fuse or button problem. Sometimes the volume knob will fail and you will hear sound from only one channel. May be able to order a new volume knob component.
Sep 24, 2009 | Sherwood Audio Players & Recorders
Color fades at bottom of screen
Although it is possible that your monitor is defect, you should first run a monitor test to see if you just need to adjust some of the settings. Go to this webpage and just follow the instructions.
The test are done best in full screen mode (F11 in most browsers).
Do you have any sources of magnetic fields next to the monitor (speakers, halogen lights, sometimes even a cordless phone can cause distortion).
If you can, connect this monitor to another computer and see if the problem persists. This way you eliminate any hardware related issues (cable, video card).
If you have any more questions (also regarding the results) come back here and leave a comment. I will check back and see what else we can do.
Feb 24, 2009 | Acer 22" X223w LCD Monitor
Fading Screen On DELL laptop model PP01L
It sounds like defective LCD backlight. Bring your laptop to an authorized repair shop.
Dec 02, 2008 | Computers & Internet
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
