Question about Quantum SuperLoader 3 LTO-3 Tape Drive
Drive Load Error Type (3E) - Quantum SuperLoader 3 LTO-3 Tape Drive
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Mu Samsung wa400pjdwr top load is not spinning out code is 3E
3E Motor tacho fault detected Can also be caused by main PCB
If the motor tacho signals are inputted less than 2 for 2 seconds after main drive motor started, this error will occur.
  • Check motor
  • Check motor tacho
  • Check all connections and blocks to the motor
  • Check connections on the main control module
  • Check main control module
Apr 05, 2015 | Samsung Washing Machines
Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Samsung error code 3E?
Aug 12, 2010 | Samsung WF328AAW Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH2400A Front Load
If it's still there, pop out the front bottom panel. There is a Technical Information packet stuffed behind it.
3E says:
"Drive System is not working correctly. Bad windings, speed sensor, wiring connections, or Control Board."
Jan 18, 2008 | Maytag MAH2400A Front Load Washer
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
1,491 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
