Question about SanDisk Sansa Clip MP3 Player
New SanDisk Sansa Clip freezes
I got a new Sansa Clip and when I turn it on it just freezes on the SanDisk Sansa logo screen.  I tried holding the power on/off key down for 20 seconds but that didn't work.  Any ideas?
  • 19 more comments
  • chan2007 Dec 22, 2007
    Same problem...I will not go beyond the Sansa Logo....
  • CB11 Dec 23, 2007
    That worked.  Thanks.
  • Anonymous Dec 24, 2007
    have same problem...locked on Sansa screen
  • troutslayer Dec 26, 2007
    My new Sansa worked for a while today and then froze on the record screen. I tried to reformat with no success. Any ideas????
    Please help.
  • lovr ya Dec 26, 2007
    GET STUCK ON LOGO SCREEN AND WON'T GO ANY FARTHER.
  • Hoock Jan 01, 2008
    The MP3 player is froze in the record mode, tried to reset but when we turned on the player it was still in the same mode. Previously it was stuck in the FM radio mode. Can't seem to get to the Main Menu, can you help?
  • blakelara Jan 02, 2008
    The screen is frozen on Sandisk & my computer is not recognizing the device.
    During a brief window when it was recognized & unfrozen I reformatted it.
    Then it just froze again.UGH!
  • Anonymous Jan 05, 2008
    My sansa clip used to work great. Now, after I unplug it from the computer it freezes. I tried the solution, but I don't know if it applies because I have a Mac.
  • Anonymous Jan 09, 2008
    i turn it on and it stays on the sansa screen what do i do
  • p3ach3z Jan 09, 2008
    i pluged in my sansa 2gb into a mac computer and as i pulled it out it just frooze on me and hasn't worked ever since. what do i do?
  • dodabug Feb 13, 2008
  • Gigante707 Feb 16, 2008
    I tried holding power it would turn off but when I turn it back on it frezzes again got anything
  • waffles79 Mar 28, 2008
    When i try to turn on my SanDisk sansa it freezes. I try to turn it on/off but it seems like nothing happens and it gets stuck on the SanDisk logo screen. WHAT DO I DO?!?!?!?
  • cityk Apr 01, 2008
    my new sansa clip isnt working when it's on there's only the logo appearing.ive tried holding down the power switch and it still doesnt work.
    the sansa clip wont work t only shows the sansa logo ive tried holding the power switch down it wont work
  • timmy schlei May 11, 2008
    i was just going to delete a recording and it just froze what should i do?
  • Anonymous Aug 10, 2008
    how do i un freeze it
  • Anonymous Dec 19, 2008
    I updated my sansa clip 4GB by the latest updater and then I met the same problem. Therefore, the latest firmware may still have the problem or there are  another cause of this issue???
  • Anonymous Mar 27, 2009
    I let mine completely die and tried to recharge it but it doesnt go past the start up screen where it says SanDisk
  • Ren-kun May 03, 2009
    i just got a SanDisk Sansa Clip MP3 player (1GB) and i'm having the same problem and i have tried letting the battery die all the way... (left it in room for a month) and when i turned it on i still get stuck at the start up screen
  • Anonymous May 04, 2009
    I tried to go back to my songs and it wouldnt let me it just is frozen and it wont turn off.
If you hold up the power button on it for 10 to 15 seconds it will turn on. I'm sorry if it doesn't work for you..but it worked for me
Posted on Aug 22, 2008
I had this situation a couple of times. I just wiated for it to use all the battery power and turn-off by itself. After You charge it and turn-on again, it should work, it worked for me :)
Posted on Mar 17, 2009
Won't shut off screen displays 012510-213901 this is a sandisk sansa clip+ 4gb purchased yesterday
Push up/press power button and hold for 10 to 20 seconds, It will turn off.
What is your firmware? you should update the new firmware at sandisk forum,
http://forums.sandisk.com/sansa/
good luck
Jan 26, 2010 | SanDisk Sansa Clip MP3 Player
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
Help my mp3
i just turned off the mp3 then switched the position to "hold" then hooked it up to the computer turned the mp3 back on then pressed and holded the center button until the connection signal came on.
Apr 01, 2008 | SanDisk Sansa Clip MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 freezes!
This should take care of it;
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Nov 05, 2007 | SanDisk Sansa e250 MP3 Player
When turning on screen fades away then restarts automatically
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
My sansa M240 WonT turn on all the way
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
4,706 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
