Question about Grandstream GXP-2000 IP Phone
How can I install a GXP-2000 IP phone, remote (from another location)? I all ready have another phone connected to the PBX box (local) but I need to have another phone remote
  • 339 Answers
The exact method really depends on your ip-pbx and whether or not you will have a persistent VPN between the remote site and the main site.
If you have the VPN then the most you would have to do different would likely be to manually set the ip settings for the phone.
If not, then you will likely be dealing with a pretty complex implementation that will require in depth work with the PBX, firewall, DNS, and possibly security certificates.
Some IP-PBX units do decent job of shielding you from the gory details but without more info to go on, i.e. details on the PBX type and whether or not you will be using a VPN, this is about as far as we can go at the moment.
If you need more, please post a follow up with additional information and we'll be glad to continue.
Posted on Oct 04, 2009
How to fix snom 300 because it cannot received calls
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Nov 16, 2014 | Snom 300 IP Phone
How to change viocemail for the 2110
IP Phones do not provide voicemail, that is a function of the PBX it is connected to, either a premise IP PBX or a cloud-based (hosted) PBX. If you are using an Asterisk-based PBX system, the usual way to access the voicemail system is to dial 98 from the phone, however you will need to know the voicemail password.
Jul 07, 2014 | Grandstream GXP2110
Does grandstream gxp 280 support vonage
Yes it supports.
SIP Account Name: Vonage
Phone Number: xxxxxxxxxx (enter your Vonage phone number)
Authentication ID: xxxxxxxxxx (enter your Vonage phone number)
Authentication Password: xxxxxxxx (enter your Vonage Authentication Password, this can be Provided to you by Vonage. Please remember that the password is case sensitive.)
SIP Domain: leave blank
Proxy Address: sphone.vopr.vonage.net
Port: 5061
Outbound Proxy: sphone.vopr.vonage.net
Port: 5061
Local Port: 5061
Register Timer: 3600
Codec: Auto
Pkt. Time: Default
Out of Band DTMF: On
-Karthik.
Sep 25, 2012 | Grandstream GXP-280 IP Phone
GrandStream GXP-2000 not booting
If both phones are showing the same symptoms then it probably means that your DHCP server is down or not configured properly. If the phones are on a separate VLAN and you have recently upgraded or replaced your network switch then it could be misconfigured as well - specifically it may require you to configure a DHCP helper address.
Dec 16, 2009 | Grandstream GXP-2000 IP Phone
How do i log into the PBX box?
Please consult the company that installed your PBX, or check the documentation they SHOULD have left.
Oct 09, 2009 | Mitel 5220 IP Phone
Trying to set up phone on VOIP at remeote
If there is a problem with the connection, or low bandwidth, you can change the protocol to just use G 7.29 to improve performance. That is if the PBX supports it.
Jul 23, 2009 | Mitel 5212 IP Phone
Change clock time.
The XN120 I know is a PBX, so setting the time sets it for all phones connected to the PBX. The time can only be set on an XN120 system phone which has an LCD display (or a PC - see below). It's quite complicated - refer to setup guide such as
http://www10.GIScafe.com/nl/newsletter_confirm.php?enc_email=ZGF2ZS5jb3ZlbGxAc2lnbWFzZXZlbi5jby51aw==&subscriber_key=5d4ff921b647525ca172f7fb11ae56b4
Some of these PBX systems have TCP/IP network cards installed so the time can be set from the NEC PC-Pro configuration program run on a network connected PC.
Nov 10, 2008 | Lands Phones
Grandstream budget tone 200
Go to internet
Type your the ip phone address
type admin as password if you never changed it
That's it
Nov 04, 2008 | Grandstream GXP-2000 IP Phone
Gxp blinking
Replace your power cable.
Dawit
Jun 28, 2008 | Grandstream GXP-2000 IP Phone
Loosing time on the ip phone
The phone should not lose or gain time unless the time on the PBX that it is connected to is being changed. Sometimes the IP phone may lose connectivity to the PBX and the time may stall but when the connectivity is reestablished the time should update.
Feb 11, 2008 | Avaya IP Office 4620 Telephone 700212186
Grandstream GXP-2000 IP Phone Logo
194 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Dave
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
