Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer keeps tripping the circuit breaker
Old dryer kept tripping the circuit breaker so got a newer one since the old one was at least 15 years old. But now the newer one that just put in last night is doing the same thing. What could be causing this?
    Sergeant:
    Champion:
  • 205 Answers
Hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Posted on Oct 02, 2009
Why did my Trane air conditioner trip the circuit breaker?
Could be the circuit breaker is bad,only way to find out is to replace it,you can't tell by looking at it,my Dryer kept tripping mine,finally went to Home depot and bought a new one and it has fixed the problem,but It could be something else.I even called a electrical company and they said it just tripped the circuit breaker,and they reset it and the dryer worked for about 10 minutes after they left and it tripped again,had to pay them for service call and they didn't fix it,I did.Take your old one to match it up to be sure.
Jul 31, 2017 | Heating & Cooling
Whirlpool frontload dryer trips circuit when started all of the sudden. Gas dryer, replaced circuit, must be dryer
The dryer should be on a dedicated circuit. Is anything else on the same circuit? Try plugging the dryer into a different circuit and see if it still trips the breaker. The breaker trips because there is either a short or too much power is being drawn for the size of the circuit. Check how many amps the dryer uses, and make sure the circuit is rated for that load. If the dryer needs a 20 amp circuit, and the circuit it is plugged into is only a 15 amp circuit, that will trip the breaker.
If all that is good, there is a problem with the dryer, either a short or the motor is drawing too much power, which usually means it is at the end of it's useful life and need to be replaced. If you are handy, there are sites you can go to which will show how to remove the motor. There are appliance parts stores which will test your motor, and sell you a new one if you need one. I have a 30 year old dryer that still runs, with it's 4th motor and 5th belt, if you are handy. The cost of a repairman to come out is probably not worth it after the dryer is about 10 years old, better to replace the dryer at that point. The new ones are much more energy efficient and do a better job than the older equipment, so they are worth the investment.
Aug 02, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Hello: I have a Maytag MDE9700AYM that was purchased three years ago but has been installed for less than one year. After the unit runs for 10-20 minutes, the circuit breakers trips off. Otherwise the...
It's possibly the circuit breaker rather than the dryer itself. Usually when it trips, it is overloaded or shorted. Overload can be a result of a loose connection or a bad heating element,when you remove the old breaker, see if it has some noticeable burn/corrosion marks where the wire is screwed down, I think replacing the breaker will fix the problem. Hope this helped Tim
Nov 07, 2010 | Maytag MDE9700AYM Electric Dryer
I have a 5 to 7 year old kenmore dryer it runs but does not heat. should i repair or just buy new?
Be sure to check your breakers for dryer some times only one side of the 220v will trip and the dryer will run but it wont heat. The element is the only thing that is 220V. Hope this helps. A 7 year old dryer is not that old most dryers is good for 12 to 15 years.
It would be good to pay a service call and an est. them make the choice to fix or replace
Nov 04, 2009 | Dryers
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Dec 12, 2007 | Refrigerators
Breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
Sep 11, 2007 | Heating & Cooling
GE Profile Harmony DPGT750EC Electric Dryer Logo
581 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
