My konica 1015 copier is starting to copy very fuzzy on 1.0 size, but on bigger or smaller size it copies fine
    Guru:
  • 389 Answers
Violated adjustment 1 mirrors. Vpolozhenii 1:1 зпервое mirror occupies the invalid position. Do clear optometrists and check the position scanning device in position 1, can be not in its place from for obstacles or slanting. Attentively examine the device, remove glass and slowly move, must be всободный move and return in положенеи 1 on перекритию sensor. This does without stekla. move different scales and arouse to find not faithfull position in scale 1;1
Posted on Oct 03, 2009
Konica Minolta BH164 Copier gets paper jam in LGL and FS size papers only what to do
then place the LGL and FS in tray one does it work??? is this printing or copying???
Jul 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Printer comes up with (caution! aps size error) error message after i press the start button in the control to make copies.
1-Press "Tray" button or "Paper" button from the panel.
2-Select the paper size from the menu shown.
3-Now press the start button. No caution will appear.Next time use the same procedure for making copies.
Dec 28, 2010 | Konica Minolta bizhub 180 All-In-One...
Konica 1015 copier has been in storage for 10 years
You need a drum cleaning blade. These blades will go bad if left unused for that much time. This part cleans all that toner off of the drum in between copies. Cheap part at about $25.00 to $35.00
Just google konica 1015 drum cleaning blade and you will find one.
Dec 28, 2009 | Office Equipment & Supplies
Konica copier 1015 copies come out black what is the problem? please help trouble shoot this.
The exposure lamp (light source) that illuminates the original has failed. This may be fused in your machine but the fuse rarely blows without reason.
You should be able to verify this pretty easily by lifting the cover and doing a blank copy.
Oct 16, 2009 | Konica Minolta Office Equipment & Supplies
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 1015 copier with image ghosting problem
I hope the correct toner is in there.
It could be that the cleaning blade on the drum isn't working or the charge isn't working right.
Sep 17, 2008 | Office Equipment & Supplies
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
Blur copys
The 1015 / 1120 were prone to the lens drive gear cracking, and not holding to the shaft.
Sometimes you will get a lens initializing error, sometimes you wont.
But this is most likely the problem.
Feb 01, 2008 | Konica 7410 Laser Printer
Printer does not print or copy the full page
hi pls set paper size & type setting set for a4
Jun 14, 2007 | HP LaserJet CM1015 All-In-One Printer
jasbo
jasbo
