Question about Refrigerators
Need adapter that goes on refridgerator that connects to ice maker hose
  • anantha reddy
    anantha reddy May 11, 2010
    hello mam please call the engineer he will do the necessary.
  • 10,865 Answers
Go to any hardware store, or home depot with the book from the fridge and the hose or at least measure and make a drawing of each end so you will buy the correct adapter.
Posted on Oct 02, 2009
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
How do i fix ice maker on kenmore elite refridgerator
It could just be a frozen water tube without enough slope to drain leaving water traped between the back wall and ice maker. Another problem could be that some models have a screen wire filter on the inlet electric water cylinoid valve that controls the water to only the ice maker. Located under the refrigerator. Yours will have two or a double and a single. Also unplug the refrigerator then unplug the two spade connection and check the electric windings for a open circuit. Anything under 1000 down to 25 ohms are good. To find which valve controls the ice follow the hose. Or have some one push the wat
Oct 16, 2013 | Refrigerators
Where do I connect the water hose in the back for the refridgerator
what kind of water hose.this ice maker should fit 3/8 cut off value and sit in the back at the bottom
Oct 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I am trying to replace the water dispenser hose. The hose sold to me is 1/4 inch. The hose on the refridgerator is larger/ The 1/4 inch does not fit
You are correct.Your looking for a 5/16. Some models have them that have the water and ice in the door but the 5/16 normaly goes to the water in the door rather than the ice maker. You will also have trouble finding the compression fitting unless you get it through a appliance place or auto parts place.
Please rate solution
Aug 25, 2009 | Amana Refrigerators
I WAS WONDERING ABOUT THE ICE MACHINE,IT ISN'T
check for water then check water valve where hose connects. the see if the is water in ice maker if so then wait for ice, if no water it could be the valve
Jul 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Exactly the same.
The hose that carries the water from the top coil to the evaporator pan is plugged with ice. You need to leave your unit unplugged for a long time so the ice in the drain hose can melt. If you restart it too soon the problem will not be solved.
Jun 15, 2009 | Gladiator Freezerator Top Freezer...
Hose comes off back of the refrigerator going into ice maker
you have a clog.you need to remove ice between hose going in to freezer and where water comes thru to ice maker
Mar 05, 2009 | Refrigerators
Please help
Are you installing a ice maker kit? If the ice maker is already installed all you have to do is connect it to the potable water supply in the back of the refrigerator and lower the bail arm to put it into operation.
Jul 15, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
