Question about HP Photosmart C4580 All-in-One InkJet Printer
Shows as offline on my mac book
I have the same printer and same problem - showing as offline when I try to print.
I'm a proud owner of a MBP just a week old and I got my C4580 today.
I also had stumbled across the problem which says "Printer is offline" when doing a simple print after setup.
If you used the Mac instruction and followed it, you probably installed the printer via the USB connection and then networked it.
I tried this and it turns out that the printer was offline and didn't print. All the set up on my Windows laptops were a breeze. For the mac though, I suggest you remove the printer and then add it again (but this time - through the network!).
If you pull up your printer properties via "Options & Supplies", you will note the following:
dnssd://Photosmart%20C4500%20series%20%5C5ZBFD7%5D._pdl-datastream._tcp.local./?bidi
The dnssd tells you that your printer is connected via a router in the network.
If it is in USB, it would be usb://.....
Also, it helps to configure your router so that it allows it a fixed IP address via DHCP. This way, your printer will always hook up to the network fast.
This should help and I hope it does!
regards, Ken
Posted on Nov 25, 2009
    Scholar:
  • 53 Answers
If you are using Windows XP perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Posted on Oct 03, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Always shows "Printer offline" status (Mac OSX)
Have you installed the printer driver for the selected printer??
Oct 30, 2017 | Samsung Clp-325 Colour Laser Printer
Can't print from HP 2540 aio to my Imac PowerPc G5 OS X 10.5.8 The Imac keeps telling that the printer is offline.
A quick look at the HP web site for this printer shows that it only supports Max OS X 10.6 and later. These versions only support the intel processor based macs. Your PowerPC mac is, unfortunately, obsolete as far as Apple and the peripheral manufacturers are concerned and is not supported.
Dec 19, 2013 | HP PhotoSmart 7350 InkJet Printer
Printers driving me crazy; I have three HP printers and none will print for me now
To Add and set as Defult Printer Go to system Preferences>Print and Scan > "+" symbol on left corner and add the printer.
when you give a command of print there you can see the list of printers and you can select the printer you want to print from.
Oct 29, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Wireless keeps saying printer is offline when I try to print, but im using a MAC Book
hi there!
try restarting you mac book and see if the printer icon goes online. you can check on the manuals, drivers, and faq's for that printer too on this link:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3752459
Apr 07, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer will not print shows ready and when asked to print goes offline and doesn't print. Tested cable - ok (scanner works ok) tried with two other machines (PC &Mac) and different cable same result. ...
make sure your fire wall is not blocking. you can also go to device printers and you should see your printer at bottom screen with yellow mark on it right click it then trouble shoot then fix.
Feb 06, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
Printer shows offline/Scanner has no destination list
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Dec 18, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Mac os 10.5
I think the problem is that lexmark never made this printer mac os compatible. I have one and the disk it came with was for windows only, while i have a 3300 series and that came with a disk for both windows and mac.
Jan 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP Photosmart C4580 All-in-One InkJet Printer Logo
367 people viewed this question
Seeker5211
Seeker5211
