Question about Breezaire WKE 6000 Wine Cooler
Excess condensate not draining properly - Breezaire WKE 6000 Wine Cooler
  • anantha reddy
    anantha reddy May 11, 2010
    hello sir/mam
    please clear the blockage of the drain pipe.
I have a small 5000 btu window unit air conditioner made by arctic king does not have a hole for the excess water to drain.
I've repaired a lot of window units because someone has drilled a hole in the pan, to drain water, and hit the coil. Please do not drill any holes in anything! These units utilize condensate water to help reject the heat in the outdoor coil. If water is reaching the outdoor fan, it either does not have the proper "lean" or slope, or it's designed to allow water to reach the fan, and not much you can do. If it is designed to allow water to cool the outdoor coil, and you were to drain that water so that no condensate water cools the outdoor coil, this will allow the unit to operate with an excessive outdoor coil temp, and shorten the life of the compressor, or cause the unit to operate poorly/warm supply air temp. Try to give it just a little more "lean". Hope this helps!
Aug 18, 2017 | Heating & Cooling
Why 2004 Buick lesable running hot when ac on
Excess heat not being properly disposed of. Check the AC condenser fan for operation, clean condenser and radiator, proper cooling system levels and thermostat operation.
Sep 18, 2015 | Buick Cars & Trucks
2002 kia sportage develops condensation under glove compartment with low airflow from vents.The vent temperature drops and blower air volume decreases as car is driven?
check location of a/c condenser it sounds like it is freezing up and is probably located under glove box. also check drain hose for a/c condenser that it is allowing excess water to escape from a/c condenser box
Aug 01, 2014 | 2002 Kia Sportage
On the left rear theres a filler box with aflowter to stop systeme why wont it fill with water
The float is the condensate sensor.. It shuts the unit down when there is excess condensate in the bottom of the unit, and the unit needs to be drained. You should never try to fill the unit with water. If you have no water building up that is actually a good thing and it means the unit is working properly, venting moisture though the warm air duct.
Jun 22, 2013 | Windchaser PAC9 Air Conditioner
Maytag Plus MTB2456AEW leaks from inside refrigerator onto the floor.
condensation- bad door seals. replace seals.
in fridge- condensate drain plugged. unplug drain under coils.
under fridge- condensate pan full. empty pan.
Aug 27, 2009 | Refrigerators
Refrigerator is sweating filling drain pan
A leaky door gasket will allow excess moisture in and it will condense on the cold surfaces and can also cause excess frost on the evaporator coil causing more water to go into the drain pan.
A good gasket will hold a dollar bill securely all away around the door.
Jul 01, 2009 | Whirlpool GR9FHMXP Top Freezer...
My ac window unit does not seem to have any obvious drain hole or plug
DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
Jun 21, 2009 | Frigidaire FAC126P1 wall/window Air...
Honeywell furnace humidifier thermostat & other
sounds like to me you have a condensation pump attached to your hvac system. this can be used to pump water produced during the cooling of your house when in the a/c mode. if you have a typical bypass humidifier, you will have excess water running past the water panel and it must be sent to a drain of some kind. I would imagine the pump is being used to get your bypass water to the drain. another scenario may be that you have a 90% condensing furnace. if your exhaust pipe for the furnace is made out of pcv pipe, it is a condensing gas furnace. it will produce water when it is running. the water if from the combustion gases being condensed in the secondary heat exchanger. this is normal. some condensing gas furnaces will draw combustion air from inside the house and some will have a second pvc pipe that is used to pulll combustion air from the outside of the house. either way, it is not dehumidifying your house. the humidifier should be able to keep up if it is runnng properly. you should have water running out the bottom drain of the humidifier any time the fan on your furnace is running and the humidistat is calling for humidity. if this is not happening, it is not wired properly.
Jan 16, 2009 | Honeywell Power Humidifier: Furnace...
Extreme condensation, pooling in the floor of T-49
Please check your drain. These units have a drain pan for the condensation. After these units have been running the drain may develope a build up of debris.
Sep 26, 2008 | True T-49 Side by Side Refrigerator...
Breezaire WKE 6000 Wine Cooler Logo
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
