Bios settings? i changed my bios settings first i pressed on load optimal defaults and 2.load fail safe defaults .so after that when i start up my computer shows a informatiom "ethernet adapter 10/100 .media testing failure and check cable pre rom exiting" like that error so i want remove this information because my computer not show this type of information before change the settings and i again pressed button load optimal defaults because someone advice me that you again pressed on load optimal defaults. and i want to know where i found my ethernet adapter seeting please give me help
  • Gbenga May 11, 2010
    youve probably disabled the onboard LAN. try and locate it in the cmos and manually enable it.
  • joecoolvette
    joecoolvette May 11, 2010
    Computer name, Model Name, and Model Number
  • 329 Answers
These settings are related for boot up troubleshooting....system need startup point that is called boot up point.. Now there is sequence for search for boot up device that contain boot up point These device consist of floppy drive, hard drive, cd rom, usb drive and lan.....so try to set your boot device priority with hard drive as first device....this will solve your boot up problem....do reply back
Posted on Oct 03, 2009
Testimonial: "thanks for help many advice but your suggestion do mmy work or sol;ve my work can i add you my friend my email id is "yadavharish98@yahoo.com""
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
My computer wont turn on lights up but wont turn on
What did you do in bios ?
You might have to go back into bios and set fail safe or optimized defaults.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Dec 22, 2012 | Abit AS8 Motherboard
Set bios for xp install
hope this helps
Aug 03, 2012 | MSI PM8M-V Motherboard
I cant get into setup when starting up computer it is a presario sr 1000 desktop
or
hope this helps
Jul 29, 2012 | Compaq Computers & Internet
What is the difference between fail-safe defaults and optimized defaults in bios
failsafe defaults are settings that aren't necessarily the best settings for the computer but should work with any operating system, optimized defaults utilize the hardware to it's optimum capability
May 04, 2012 | Computers & Internet
How to install an os on an old pp2180
hope this helps you
Apr 18, 2012 | Computers & Internet
Set up utility?
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Mar 30, 2012 | Compaq Presario 5000 PC Desktop
When open the compeuter must press f2 for work my computer
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
if this fails to fix the problem you might try safe mode
is this the only key you have to press might be a log in requirement you have enabled
depending on your operating system click start control panel user accounts change the way you log on you should see log on options change the way users log on/off
learn more about user accounts increase log on security
hope this helps
Aug 24, 2011 | ASUS P5RD1-VM Motherboard
Bios setting problem?
Optimal Defaults and Fail Safe Defaults are two different sets of values. If you set one after the other the second would have replaced the first. Try setting back to optimal again.
If you still see errors relating to the Ethernet adapter find the Ethernet adapter in your BIOS settings and set it to Auto. If you still see errors try all of the available Ethernet settings.
Hope this helps you get your computer running again.
Oct 01, 2009 | Computers & Internet
Cannot installed window xp
you need to set the first boot device to cd-rom and then enter a good non-scratchy xp disk and boot again.....you will get a option to press any key to boot from cd then press any key..
Aug 01, 2009 | ZT Group CISNET A7022 PC Desktop
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
