Question about Grohe Movario Trio Hand Shower - 28441
I just bought a new Grohe Movario handheld. The
I just bought a new Grohe Movario handheld. The flow is so low I will return it unless I can solve that problem. There is a plastic white filter and underneath is a plastic green fitting which I assume is the restrictor. Am I correct and, if so, do I remove it even I have to break it to get it out?
  • 129 Answers
Yes this is the water saver feature. If you screw a drywall screw into it alittle you should be able to pull out with pliers.
Posted on Oct 02, 2009
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
Shower head is making high pitched whistling nois
The holes are probably clogged from hard water. Take the whole head assembly and dip it in a bucket of CLR for an hour or so. Then rinse off and give that a try. If your cheap, you can use a bucket of white vinegar and a little bit o water, but the smell is most disagreeable.
Feb 12, 2010 | Grohe 28444000 Chrome Movario Movario Five...
Low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Dec 20, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Have Grohe remote control shower. Could u tell me what size/type of battery is needed (if any)for the 2 units, 1 outside shwr and the shwr itself. Tks John
John; Most remotes use litium button batteries. Try to remove the old one and get the info off of it. Or see what the battery compartment looks like. Good Luck.
Button batteries are readily available at most radio shacks or drug stores.
Nov 06, 2009 | Grohe Shower Movario 28 443 Chrome...
The Grohe Movario shower head how do unscrew it to clean the head
On the face of the shower head where the water sprays out of ,their should be a threaded nut to unscrew This is called the aerator.This is the part wher the filter screen is .Once you clean this part you should be up and running.
Jan 25, 2009 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Grohe Movario Trio Hand Shower - 28441 Logo
645 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
