Question about Refrigerators
Hi , my fridge door panel cracked on the side shelving area. what do i need to replace it. is this an expensive process?
    President:
  • 1,304 Answers
Depending on the model you can buy an insert for the door which is the shelves and such, just need to replace the shell, about 32 1/4 screws around the edge under the gasket,,,,
if you dont have them, to replace the shell, you would need to buy the entire door.
Posted on Oct 03, 2009
Not freezing water pooling door shelves
sounds like coils froze up... in freezer about halfway down there is a panel. unplug fridge.. remove panel, use blow dryer to thaw coils. this will cause a lot of water to come out. once they are thawed out, replace panel, plug it back up and it should be fine... sounds like someone left it cracked open overnight.
Oct 25, 2013 | Frigidaire GLSZ28V8GW SIDE BY SIDE...
Fresh food door will not close/seal
Check to see if one of your door shelves is bigger (sticks out more into the fridge) than the other ones. If it is, theses shelves can cause door closing problems. Try removing the shelf from the door and closing it again. If this shelf is the problem, call subzero at 1800 222 7820 and give them your model and serial number, and they will send you a new standard depth shelf to replace the deeper shelf at no charge, these shelves caused a lot of door closing problems when they came out. Hope this helps!
Sep 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Hi Fridge side fan was noise for 3 days and now
Hi I have same unit. Problem is the fridge circulator fan gradually ices up, becomes noisy and then stops when frozen up.
To fix quickly you need to remove all shelves drawers etc, then unfasten lower panel fixings and find the whole back is full of ice including the fan.
Remove panel , and de-ice fan etc until fan rotates freely. Replace and all will be OK.
Otherwise empty and defrost normally but be prepared for a long wait
Don't call an engineer he will just do same. Hope this helps
Mar 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
I have a 10 yr old fridgidaire side by side in the door ice and water and the top section of the freezer and fridge are not cold but the bottom shelves are okay.....any ideas?
Good day,
That is typical of the freezer fan motor not running. Open the freezer door and see if you can hear and feel the fan motor running.
If not replace fan motor. You need to remove the back panel in the freezer compartment to access the motor.
Nov 05, 2009 | Refrigerators
GE side by side freezer shelves falling down
This appears to be a known problem with at least a couple of GE models (It has been happening in our freezer too). There is a GE Service bulletin at https://customernet.geappliances.com/OTIS/fs/home_images/REF01-10.pdf that seems to describe the fix as them sending out new shelves (and maybe someone to install them?)
Sep 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Broken Shelves
The only shelves you'll get for this model is probably the ones offered by the manufacturer.
The best way for longevity of the shelves, is to make sure that you do not put too many heavy things on it, and be careful when cleaning and replacing shelves..
May 28, 2008 | Frigidaire FRS3R5EMB Side by Side...
Fridge part not cooling properly
Miss Sugarbaker, it almost sounds like a airflow issue, but check to see if the interior light is going out when the door is shut. This would cause the higher temps on the top shelves. The damper assy. is controlled by a thermistor that sends the temp info to a main board in the back. If this thermistor is bad, the damper will not funtion properly. Catriver..post back.
Sep 27, 2006 | Hotpoint HSS25GDMWW Side by Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
