Question about Friedrich M18YE Air Conditioner
Water droping Dear Sir! My air conditioner, is dropping water. Why and how to fix it?
  • 80 Answers
Your drain pan is not draining. Use a wet vac to **** the drain line from the outside. This will pull out the blockage and you're back in business. Do not blow compressed air into the drain. This pushes the blockage back up into the drain pan.
Posted on Oct 04, 2009
  • 334 Answers
Why? Because as the air passes over the coil and is cooled, the humidity in the air condenses and drains into the drain pan. When the drain line or pan gets clogged, it no longer drains to the outside. That causes the pan to overflow, and drip into the house.
How to fix it? You will need to locate the drain line and remove the clog. This is easiest done with a wet/dry shop vacuum.
Posted on Oct 03, 2009
My electrolux split system air conditioners (ese30hra) only operates on high speed. What could be the problem and what could I do to fixit.
The air conditioner removes humidity when it's operating. This is where the water is coming from. Proper installation requires the unit to be tilted slightly down in the back so condensate will be picked up by the outside fan and be dispersed. The fan speed problem can be either a bad speed control relay or a possible open winding in the motor itself.
Dec 05, 2013 | Electrolux FRA102BT1 Air Conditioner
Air conditioner leaked a lot of fluid that looked like water after being on all night. Do you think this is an easy fix, or what do you think is wrong with it? Thanks
All air conditioning units have built in drains. When the drain is clogged the water fills the drip pain and spills out. An easy fix is to open you unit and just wipe the drains. If you cannot find the drain find where the water is coming from and trace the water to the source. The other possibility is that the unit has a dehumidifier that is not properly sealed and it is leaking the water it collects if so find the dehumidifier (usually labeled) and pull the cover off clean the seal and put cover back on (may snap into place) and see what happens the next day.
Aug 21, 2011 | DeLonghi PACA110 Portable Air Conditioner
Nokia 1661-2 show display "test
HI saidijohn,
If you have dropped your mobile in water, then i am afraid even if you get it fixed it would be too expensive.
I suggest for you to buy a new one.
I hope this helps.
Jun 18, 2011 | Nokia 1661 Cell Phone
I have problem regarding water tapping in indoor unit of split a.c.
dear sir /madam
please do every week clean your split type a/c,s filter it,s main coz who responsible for block the drain water line and after that split indoor drain ac unit drain water from inside of the unit , try to find out the drain water line of indoor unit of air conditioner the make clean it and also check it i mean keep some fresh water for make test its drain line it have been open or not if water is going easily then ,it,s ok
it,s up tp you if you think you can do it or contact to it,s technician for do solve this problem.
thank you for using fixya for get solution
hope answer the question
please vote!
Jul 07, 2010 | Whirlwind FH-778 Air Conditioner
My air conditioner is not producing any water
It will take a full season of runnig to produce a cup of water. Most moiisture evaporates and is exhausted out the hose.
May 31, 2010 | Kenwood KW85 Air Conditioner
Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Haier hprd12xc5
why don't you try www.247servicecenterinfo.com, they have listing of all HAIER service centers in india.
Jul 07, 2008 | Haier HPRD12XC5 Air Conditioner
Air conditioning unit is spitting out water
unit need to be tilted to the rear as it is installed in the window for proper drainage of condensation water off of the interior coil
the fan on the rear will pick up the water and remove it
tilt it back a little
May 27, 2008 | Heating & Cooling
Maytag Air Conditioner NMPEB08F2A
IF there is a lot of water, the float switch probably tripped. Happened to me, the water motor failed. When this happens there is no water blown up into the evaporator coils and it just accumulates.. and trips the float sensor. 2 problems with replacing the water motor. I can't get the part easily, and you have to remove all the plastic shrouding and drop the bottom out to get to it. (Steve)
Aug 02, 2007 | Maytag NMPEB08F2A Air Conditioner
Friedrich M18YE Air Conditioner Logo
634 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
