Question about Garden
How to remove mulching shute from yardman 13/38 mower
    Guru:
  • 1,326 Answers
Most pop on/off and others may have a bolt or 2. Should be obvious which you have
Posted on Oct 02, 2009
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Jun 02, 2009 | Garden
Problem with snowblower electric chute
This was poorly designed , you will have more problems unless you fix it right as the bolt heads underneath the shute ring is rubbing the right stop and on top of the motor housing the main problem is the left ring stop is hanging up on the front motor mount.
to fix it,remove the motor,grind about 3/16" off the rear shims and file about the same off the bottom of the front motor mount,remove the motor mount bracket,file about 1/4" off of the right stop,remove the shute and the shute ring, mark the left stop before removing,bend the left stop up about 3/16" be careful not to bend the ring,replace motor bracket first than shute ring and shute than replace motor.if your shute has hung up often you may need to replace the motor,you can go to an auto parts store buy a 1999 chevy lumnia passenger side window motor around $50.00 vs yardman $360.00 you will need to tap out the mount holes with a 5/16 standard thread tap and tap from the bottom of the motor,don't forget to file the bottom of front motor mount.
Jan 18, 2009 | Winter Sports
Saw your post about Black and Decker MM525 Lawn Mower
Most lawn mower mfgs offer a mulching kit which usually consists of a metal plate to block the discharge opening and a mulching blade which just has a longer sharpenned cutting edge.
With a little labor you can make your own.
Johnww1422@aol.com
Apr 19, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
