Question about Canon PowerShot S5 IS Digital Camera
The LCD is sometimes not lighting or shows upside down. I will have to turn it on and off a couple of times to get it working right. What could be the problem?
My torch only light when turned off. Why? Also when I refill it it won't stop spraying out the fill valve? It worked fine till it was turned upside down. Could that be the problem?
Hard to see on the picture but it looks like a bernzomatic? Ive got a different model to yours and ive used it in all sorts of positions when brazing. I have noticed sometimes when its very cold weather, turning it upside down sometimes causes it to splutter and go out. That would be from liquid instead of vapour coming out. The lquid spraying out of the fill nozzle is probably due to a stuck valve or it may have some dirt in it. Try pushing the centre pin and out a couple of times releasing the gas.It may clear itself. Wear safety glasses and be careful when doing this!
Sep 17, 2015 | Cars & Trucks
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
Dim light but wont turn on fully
You will need to "reboot"
While pressing down the Nook button (upside down u on the front of the tablet), press the power button on the side. You will need to hold it for couple of seconds.
Mar 07, 2014 | Barnes & Noble Nook HD
Plays back on lcd screen upside down at times
When the viewport is completely flipped around so you can see it when you are looking at the lens, it automatically flips it upside down so it is right side up to the viewer. Make sure it is locked into the correct position to prevent this from happening.
Hope this helps
Dec 05, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sceptre 40" 1080P LCD HDTV Display Upside Down
Sceptre X37sv-Naga 37 in. LCD Television
The screen wont come on my sidekick 3...ball still works
Yeah, more than likely the lcd cable connection is loose. That is what the white screen usually indicates.
It is fairly easy to take a apart and reseat.
Follow the guide at the link below
Fix Sidekick 3, Sidekick ID, Sidekick II White LCD Screen
Jun 19, 2009 | T-Mobile Sidekick® 3 Cellular Phone
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Image upside down on my Audiovox VE1020
Check the screen position switch, they sometimes get fouled especially if installed in a kitchen.
Apr 07, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Canon PowerShot S5 IS Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
