Question about HP DeskJet 5650 InkJet Printer
Printer in error mode
It starts to print then stops and in error mode
  • helenstoy Dec 21, 2007
    yes
    now does not print in error mode
    Scholar:
  • 54 Answers
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Posted on Dec 22, 2007
2 Suggested Answers
  • 2692 Answers
SOURCE: Printer starts to print but then stops and says, "printing errors
I would start by loading the new driver:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jan 15, 2009
My printer will print one page and stop printing in the middle of the second page.
I think you are seat only one print one time so plz check it. Go to printer option and setting. One time you check printer after your printer which mode show like active print mode, print error, hold print mode etc.
I suggest you Full uninstall printer driver and re-again install printer driver. If not solved then change printer cable.
If more help contact Dell printer Support Technician. and TechSupportPrinter expert team.
Thanks.
Jan 11, 2014 | Dell Photo 926 All-in-One Printer
My printer multifunction Aficio sp C240sf show the error message sc542
For this model specifically, the following will get you into service mode.
Hit "Clear / Stop" Buttom then "107" then hold down "color print" buttom for some sec then you are in service mode
If that doesn't work, you can also use Clear/Stop,1,0,7, Clear/Start.
Each key should be pressed and held until you hear a beep
Sep 09, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
My canon inkjet printer mp276 error blinking 07P
Causes : Error P07 shows you printer ink abosorber is almost full. Solution : Here is your answer to fix your error. So you need to follow the instruction step by step...
Step 1: Entering Service Mode
* While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models). * While holding the Start/Stop button, press and hold the POWER button. * When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button). * Press the Start/Stop button TWICE (still holding the POWER button) * Release the POWER button. * Wait for the LCD to display "0? (zero).
Step 2: Using Resetter / Software Download Ressetter ; http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
* Run "service_tool 1050.exe". * Confirm detected USB-port numbers on USB port column. * Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete. * Click "platen button" on the "Clear ink counter" section. The printer will print again. * Turn off the printer and then turn the printer on. You printer is ready for use.
Sep 01, 2011 | Canon MP270 All-In-One InkJet Printer
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
I keep trying to simply print to this printer via usb and I get this error, the printer then goes into offline mode. I can scan to the computer, so the connection must be fine. What's the deal smee? The...
There could be few reasons for this. One of then is the Printer Spooler that much be corrupted and another would be the actual printer printing drivers
Click on START button and Click on Run
Type the word CMD ( or COMMAND ) and hit enter key
You will find a new black window on screen.
Execute the following commands,
net start spooler ( hit enter key )
net stop spooler ( hit enter key )
follow the same Start and stop command for 4-5 times. End the Command with NET START SPOOLER ( hit enter key )
Disconnect the Printer USB Cable and re-connect.
It should start printing.
Dec 07, 2010 | Samsung SCX-4720FN All-In-One Laser...
Printer not working.
Start the printer in the service mode.
i. With the printer power turned off, while pressing the Stop button, press and hold the ON
button. (DO NOT release the buttons).
ii. When the Power LED lights in green, while holding the ON button, release the Stop button.
(DO NOT release the ON button.)
iii. While holding the ON button, press the Stop button 2 times, and then release both the ON
and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
Without the scanner (connect the operation panel unit.);
While holding the ON button, press the Stop button 3 times, and then release both the
ON and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power
LEDs light alternately, Alarm in orange and Power in green.)
iv. When the Power LED lights in green and "Service Mode Idle" is displayed on the LCD, the
printer is ready for the service mode operation.
Start the Service Tool on the connected computer.
i. When a button is clicked in the Service Tool dialog box, that function is performed. During
operation of the selected function, all the Service Tool buttons are dimmed and inactive.
ii When the operation is completed, "A function was finished." is displayed, and another
function can be selected.
iii If a non-supported function is selected, "Error!" is displayed. Click OK in the error message
dialog box to exit the error.
(7) Main Main ink absorber counter
resetting
Set a sheet of A4 or Letter sized plain paper. After
the ink absorber counter is reset, the counter value
is printed automatically.
(8) Platen Platen ink absorber
counter resetting
Jul 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Printer not loading paper to print / error #3
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Jan 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP DeskJet 5650 InkJet Printer Logo
657 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
