Question about KitchenAid Washing Machines
The tub is not spinning - instead it's making a buzzing sound. Model is KitchenAid kawe570b/577b
5 Suggested Answers
mark_37388
  • 100 Answers
SOURCE: Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Posted on Mar 29, 2009
  • 132 Answers
SOURCE: top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 1382 Answers
SOURCE: my kenmore 90 series model 110 will not spin,
HI,
This problem is caused by either a broken washer tub drive belt or a broken washer tub drive coupler, look under the machine for evidence of this.If it is found to be true you have to go for a replacement of that particular unit.
Posted on Mar 29, 2010
  • 1937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Four possibilities: (Ranging from easiest to messiest)
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on May 17, 2010
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
I have to turn my tub back and forth to get it to go, spin or agitate, if I don't it makes a loud buzzing, then shuts down completely for an unknown amount of time.
there's an overload on the motor that will pop if the machine is trying to run and can't,then when the motor resets it will try to run again,it sounds like you have a bad motor,when you do get it to work does it spin and agitate normally,if so i'd say the motor is bad,if it still spins slowly you could have something locking up in the tranny. but usually a buzzing sound is the motor.how old is the machine?i mean you didn't send any info and this is under kitchen ranges so the best advice i can give to you is if the machine is old or beat up looking i would just change it out instead of putting any money into it,if it's fairly new it's your decision if you want to sink any money into it or not for a new motor
Apr 07, 2011 | Kitchen Ranges
My kenmore 90 series model 110 will not spin, makes a buzzing sound
HI,
Mar 29, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
Older model kitchenaid washing machine, model number KAWE660W...FILLS WITH WATER, but will not spin or drain....only hear a faint buzz sound
I believe this machine was actually made by Whirlpool. As such it has a drive coupling instead of a belt. These couplings break every so often. They are inexpensive and fairly easy to replace. I posted a tip on the exact details of changing one. Follow the link below for details.
http://www.fixya.com/support/r3558477-whirlpokenmore_washing_machine__can_hear
Jan 03, 2010 | Washing Machines
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Washing Machines Logo
94 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
