Question about Sharp Televison & Video
Volume Problems Sharp Aquos LCD TV
We have a Sharp Aquos LCD TV. There have been times in the past when I felt the volume was actually lower than what the screen was showing, but yesterday it really got bad. You have to turn the volume up extremely high to be able to hear it at all and then you get significant white noise with it. However, it only is happening on cable. With DVDs, the volume is working fine. We tried turning the TV off and then back on and also unplugging it and re-plugging it. No difference.
  • 381 Answers
Hello Mhursh,
You will have to go into the cable box's menu and adjust the volume control features there as the catv box can control the volume also which is what you are experiencing.
Good Luck!
Rich Lilja
Posted on Jun 01, 2017
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
james klgr
  • 362 Answers
SOURCE: Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Posted on Dec 12, 2007
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
  • 14 Answers
SOURCE: Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Posted on Jul 25, 2008
  • 5 Answers
SOURCE: Aquos Turns off by itself
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, you can order the part over EBay, not hard to install just unscrew/unplug --- plug/screw..
Posted on Aug 16, 2008
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
May 24, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sep 05, 2009 | Sharp LC-26D4U 26 in. LCD Television
Have Sky plus and the remote does not accept any codes I have got, so no volume control via Sky remote. Do you have the correct code for a Sharp Aquos 46" ? Thanks
please follow the steps below:
TV
RED + SELECT
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 32"
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
151 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
