Question about Canon PIXMA MX700 All-In-One InkJet Printer
Same problem with Error 6A80 repeatedly coming on even after turn
When I lift the top unit, the ink cartridges do not move...are they suppose to at that time?
  • tk2themax May 11, 2010
    I have this problem too. Please be sure post a solution , I will do same.
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: INK CARTRIDGE
Here is the manual for your printer:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11642#DownloadDetailAct
Posted on Sep 29, 2008
solofixya
  • 34 Answers
SOURCE: how to change ink cartridge in canon mp390
With the machine powered on. Just lift up on the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
Posted on Nov 11, 2008
micromatikal
  • 2777 Answers
SOURCE: The alarm light keeps flashing
Oh dear, that means the motorized mechanism inside the printer that moves the print head has failed. I have seen it numerous times with these MultiPass printers... About the only thing you can try is simply unplugging the printer for a good 2 minutes, then replugging it in and hoping it "kick-starts" the motor. At best this is a temporary fix and it will happen again sooner than later. Many times this does not fix it either, that means the motor has already completely failed.
It can be repaired but it is very cost prohibitive... It is much less expensive to just replace the printer unfortunately. If you happened to buy this printer within 5 years (you probably did) AND used a major credit card (not a debit card) then it may be covered under your credit cards automatic electronics warranty. Many credit cards do this. Hopefully this scenario is the one you are in... and can call the card company to file a claim on the printer and get a refund.
Regardless though you will want to get a new printer... An equivalent, well better one really, can be had for $79 with free shipping and no tax. Check this one out:
http://www.amazon.com/gp/product/B002GP7Z6Y?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B002GP7Z6Y
We don't make any money off you buying a printer so please don't think I'm just saying that to try and get you to buy a new one, I assure you it is hardware failure you have on your printer.
Thanks
Tim
Posted on Oct 04, 2010
SOURCE: error code 6A80, won't print after changing ink
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Posted on Feb 16, 2011
Canon MX870 error 6A80
Hello friend,
APP position error or Error Code 6A80
Condition: An error occurred in the APP motor.
Problems and Solutions:
  • Check for foreign material or paper debris around the purge drive system unit
    - remove foreign material.
  • Check for foreign material or paper debris around the ASF unit
  • If other solution fail, replace one off the following part
    - Purge drive system unit
    - Logic board
From http://pcmediks.blogspot.co.uk/2010/11/canon-pixma-error-codes-and-solution.html
Aug 25, 2014 | Canon PIXMA MX870 Wireless Office...
Replacing cartdiges in sx 200 epaon
Press the ink button on the control panel repeatedly. This will work if at least one cartridge is completely out. With the scanner unit open, then the first press of the ink button will move the cartridge carrier to line up the empty cartridge with an "empty cartridge" mark on the printer. Each subsequent press will cause the next empty cartridge to line up with the mark. Once all of the empty cartridges have been indicated, the next press of the ink button will bring the cartridges into the replacement position.
If you want to change a cartridge when none are empty, you need to enter the Epson Toolbox (with the printer in a Ready state - scanner unit closed, etc). Then use the software to set the printer to change the ink cartridges. When prompted by the software, open the scanner unit and follow the directions for changing the ink cartridges.
If the cartridge carrier isn't moving when you press the ink button, look for anything blocking the path of the carrier. Even small pieces of paper could stop the mechanism. Use a flashlight to check the corners. (You may want to unplug the printer and try moving the cartridge carrier by hand to check below it.) Some models have the cartridge carrier run on a plastic strip that can come out of the guide on the back. Move the strip back and up and down until it is repositioned.
I hope this helps.
Nov 12, 2011 | Office Equipment & Supplies
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
Lexmark 6170 Cartridge Error 50C How to resolve?
color cartridge.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
Cartridge error 50C
Hi there Error 50c
RegOk hope it works.
color cartridge.
Mar 16, 2010 | Dell A940 All-In-One InkJet Printer
Cartridge error 50c
Hi there Error 50c
Please try this.
color cartridge.
Dec 22, 2009 | Dell A940 All-In-One InkJet Printer
I have a Canon PIXMA MX860 and have error 6a80. i have shut off and on twice no paper jam. totally stuck
6A80 is a purge unit error, the purge unit is the cleaning assembly on the right where the printhead parks when shut down. If you can move the carriage out of the corner, use a flashlight and see if there are paper scraps or the like keeping the purge assembly from moving freely.
Oct 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cartridge error 50C
Hi there Gave it a go.
Error 50c
color cartridge.
Sep 19, 2009 | Dell A940 All-In-One InkJet Printer
Printer cartridge error
Hi there Error 50c
There is lots this happens with the dell printers
color cartridge.
Oct 25, 2008 | Dell A940 All-In-One InkJet Printer
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
Canon PIXMA MX700 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
