Question about Troy Bilt 5.5hp Self Propelled Mower
Change fuel filter it sounds like it's not getting gas.
    President:
  • 986 Answers
Remove your bowel on your carb with a 1/2 in wrench clean and check your movement of the float,use some copressed air to make sure do dirt is left install bowel ,I hope this helps you
Posted on Oct 02, 2009
Why does it miss between 50-60mph
Gas would do it all the time.Fuel filter may be stopping the flow of gas causing a misfire. It sounds water in gas but just at High RPMs like it is vapor locking (not getting the right amount of fuel). would change the Gas filter, Air filter, (gas Treatment to remove any water like Sta-Bil ).If it goes away your lucky. But it looks like a fuel pump is getting weak.
Jun 25, 2014 | 1998 Dodge Dakota
2000 toyota 4 runner. Has no power. Sounds like it isn'tt getting the gas. changed fuel filter,plugs
Bad gas or diesel in tank???
getting misfiring on all cylinders and coils won't ever fail at same time. Usually only 1 at a time.
don't ever replace the fuel filter. only if it has lack of power on highway speeds.
Apr 04, 2014 | 2000 Toyota 4Runner
How do i change the fuel filter?
First off check the fuel Injectors fuel filter and air filter as for the white smoke sounds like you're burning oil if you ran out of gas the sediment at the bottom of the tank goes in to you're fuel system
Mar 02, 2013 | 1998 Pontiac Grand Prix
How to fix a1998 buick century to start fuel filter new and airfilter turning over but not starting gets gas
Did you check for spark? It sounds like you're not getting spark. Check for spark. If you are not getting spark then it sounds like you might have to replace the coil packs. Is it running a L4 engine? If its running a standard chevy L4 its probably the coil packs. Try to replace them check again for spark.
May 25, 2012 | 1998 Buick Century
2001 avalon will not stay running
CHANGE THE FUEL FILTER, AIR FILTER
Oct 27, 2009 | 2001 Toyota Avalon
NO GAS AFTER FUEL FILTER. I AM GETTING GAS BEFORE FUEL FILTER, BUT NOT AFTER. CHANGED FILTER BUT STILL DOES NOT START
Sounds like the filter is being installed backwards. Have you checked or is it fool-proof?
Jun 24, 2009 | 2002 Chevrolet S-10
Acts like it aint getting gas
Have you changed the fuel filter.If you have run a temerary feul pipe from the tank to the carb sounds like a fuel restriction,
May 30, 2009 | 1995 Dodge Neon
POOR GAS MILEAGE
Have you changed the fuel filter? I know it sounds weird but a plugged filter will make a truck use more gas. The computer tries to compensate for less fuel by commanding the injectors to open longer. Also a plugged filter will cause excess back pressure on the fuel pump making it loud.. Good Luck.
May 29, 2009 | 2001 GMC Sonoma Extended Cab
Changing f250 fuel filter (gas)
Sounds like a fuel pump, but start with the filter.
Sep 28, 2008 | 2001 Ford F250 Super Duty Super Cab
Troy Bilt 5.5hp Self Propelled Mower Logo
89 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
