There was a power outage in my neighborhood and now the display screen wiil not appear on my unit. The fan will still turn on but the cold air from the air conditioner wont.
  • 45 Answers
Your indoor head unit board has been spicked.you need to replace it then you are in bussness again.
Posted on Oct 04, 2009
  • 334 Answers
First, disconnect the power to the unit. (at the breaker) then turn it back on after 60 seconds.
That will reset the control board. If that does not work, it means you have lost low voltage.
Look for a small blade type fuse (like those in most cars) and see if it is blown. Make sure the power is off when you do this.
If the fuse is OK, and resetting it does not work, then you will need to check/replace the 24 volt transformer.
Posted on Oct 03, 2009
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Glass stove top error message wont go out, wont turn on?
What is the model number of your unit?
What is the error code?
Nov 22, 2012 | Kitchen Ranges
My fan on my trane a/c unit is not coming on outside
Is it just the fan or the compressor as well? Check the breakers at the main panel. If the compressor is running but not the fan...It's a bad fan motor, but I doubt it.
If you have a volt meter, check to see if you have voltage at the contactor, If you do, take a screw driver and push the contactor in, see if the compressor and fan runs. ( they run together)
Cheers
Jul 24, 2012 | Heating & Cooling
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
Hi, My Hampton Bay ceiling fan died after a power outage due to a surge in the neighborhood. My question is if the motor is damaged or only the remote electrical unit. How can I test the motor? After I...
as the motor is a brushless induction motor , the possibility of damage from a spike is remote
however electronic units will suffer damage so get in an electrician or replace the control unit and start/ run capacitor for the motor
Sep 06, 2017 | Hampton Bay 24002 Ceiling Fan
T8000C Honeywell - fuses???
So the indoor fan is running and blowing air inside but it is not cold?? Is the outdoor fan running ?
Jul 20, 2017 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
