Question about Hotpoint WMA50 Front Load Washer
My Hotpoint wma50 1000spin is not pumping out all the water
    Genius:
  • Hotpoint Master
  • 1,474 Answers
Check /clean filter its located next to sump hose ..Switch off pull plug 1st ..
Posted on Oct 02, 2009
Testimonial: "Spot on filter full of gunk and a few coins cleaned and working well Thanks a lot"
I have a Hotpoint BF71 dishwasher. I put it on but it hasn't worked, it filled with water which won't drain not will it even start now. I took out the filter but I couldn't find any blockages Help!
Reset the power at the breaker, but you may need a new pump and motor assembly. The same pump washes and drains on most Hotpoint models- a solenoid is used to open a drain flap and let the water out, but a bad pump will equal no wash or drain... Hotpoint Dishwasher Pump and Motor Assembly WD26X10013 Hotpoint Dishwasher Drain Solenoid Kit WD21X10268
Jul 11, 2016 | Hotpoint Dishwashers
Hotpoint Aquarius wm750 won't fill with water
Dear Chris.
Here is offered a list of fault codes Error Codes Hotpoint Service
How to understand fault codes
Identifying Hotpoint or Indesit Error Codes
Hot Point Manual Link
Download Manual Hotpoint Service
It is possible your water supply is to low or your screens may be blocked at the inlet attachment to the washer. The other scenario a sticky or failing pump solenoid ; by which a direct replacement of the pump assembly may be required. Try to lubricate and actuate valve by hand if possible.
Fare Well.
Dec 28, 2014 | Hotpoint Washing Machines
Hotpoint washing machine won't pump water out or spin .Drum goes round
There is a pump that pumps the water out. Either the pump is bad, or the line is clogged up. Check both.
Feb 28, 2011 | Hotpoint Washing Machines
My hotpoint wf540 on off switch flases and the
sounds like your water pump has failed??
Try cleaning the filter first, normally accessed at the bottom R/H side of unit at the front.
If not, replace water pump (approx £35 for part) good luck!
Jan 04, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF325 won't pump out water
Item stuck in pump,open back and take out,unless u r in nottingham i can do 4 u
Oct 06, 2009 | Washing Machines
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Aug 18, 2009 | Washing Machines
Hotpoint machine is not throwing the dirty water out
blocked drain piping or blocked impeller on drain pump or failed coil?complete pump,that would be the area that should be looked at to solve problem
May 05, 2009 | Hotpoint Washing Machines
Hotpoint condenser dryer ctdoo
water pump at the back of the machine at the right hand bottom corner has either been blocked up with gunge which can me easily cleaned or the pump is not pumping, replace the pump
Aug 24, 2008 | Dryers
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA50 Front Load Washer Logo
517 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
