Question about Yahoo Messenger
My computer get restarted very often
When electricity goes or comes my computer get restarted suddenly,i use invertor for power back-up and i have a good UPS too even i have changed my SMPS too but situation is still same.PC's restarting problem dont occur always but happen very often.i scare that i can loose my harddisk due to sudden restarting of my PC.i dont know whether i have earthing problem of power,problem of invertor or SMPS problem..can u please help me for coping up with this situation asap.
thank you
  • micky dee May 11, 2010
    If you have a good UPS why do you need an invertor and SMPS ? The UPS should have enough capacity to carry you through a power outage, assuming it is dedicated to your PC ?
    Visited the website for 20 consecutive days.
  • Yahoo Master
  • 995 Answers
Perhaps the computer is overheating and shutting down to protect its components. If so, blowing out the inside of the computer and the heatsink fins on the processor could alleviate such a problem.
When a computer shuts down for such protection, it seldom damages the harddrive. If there's a sudden loss of power, a surge of power across the heads could damage the disks as the head drifts across them. Usually a disk check can repair this type of damage. But even with damaged sectors, most data would be recoverable.
Posted on May 21, 2017
2 Suggested Answers
  • 96 Answers
SOURCE: i uninstall my yahoo but i didnt restart the pc
i uninstall my yahoo but i didnt restart the pc after unistalling - This can be a normal issue and may be the version you installed does not require you to Restart your Computer so you can ignore this.
due to an error occured in opening a file while downloading - This error is normally occured because of the disconnection of Internet while the file was being downloaded. You need to make sure that the file is completely downloaded before you start installing it.
Posted on Sep 13, 2009
Monitor Flashes Then Goes Very Dim
Check and replace the inflated capacitors on the power/invertor board. The generated 12 volts are unstable and protection cirquit turns the invertors off to avoid damage to the IC
May 16, 2015 | HP 2311x 23-Inch LED Monitor - Black
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
I turn on my samsung syncmaster710 and it just has a black screen, with a faint (very faint box floating around it. is this a fualty backlight?
The backlight invertor seems to be defective.
Check the main power supply board for bad capacitors (visible damage ) and make sure that the invertor tubes do not light up for a moment when you power up the monitor ( in that case their probably is one or more light tube defective (burnt)) --
Sep 18, 2010 | Samsung SyncMaster 710N 17" LCD Monitor
Tv will not power up, when i turn it on the screen comes on for a second and goes back out
Aug 23, 2010 | Sylvania LC370SS8 Television
How to connect the inverterto acmains?
Battery to invertor should be quiet clear. Attach the positive then the negative lead.
There needs to be a special socket in the wall. Buy a normal three pin socket. Go to the mains. Take the line coming in and connect it to the L ('Live') marked pin. It is left one. Now take the other pin and trace it back to where electricity was originally going. What you have done is basically placed a socket in the line. See diag below:
Now take a plug. see diag and connect so that it has live going into the invertor and invertor supply coming out.
So basically you have looped the supply thru the invertor.
Be sure to read the manual. Certain invertors may have other wiring.
Electricians are cheap. Get one. It will be worth it, in case you are unsure.
Apr 22, 2010 | Inverter 500 - 1000 Watt DC to AC - Safe...
Wy Westinghouse L 1975NW monitor will give me a power light until i plug it in the back of the computer then goes out what might be the problem?
the back lights burn out. the invertors for the lamps burn. alos sometimes the powers purn up capacitors. you usually can get the power supply rebuilt
Jan 03, 2010 | Westinghouse LCM-19v1 Monitor
Suddenly power goes off. will not restart,
If there is no external fuse at the back panel, then there must be an internal fuse. I assume you tried another outlet in your home.
Nov 30, 2009 | Mitsubishi M-VR700
My monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
Mar 19, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
BeNQ FP71E Monitor won't display desktop
The problem seems to be with the monitor.When there is no Display,if you power-off and on again do you get a Benq Startup screen?If not the problem should be dry solder on the Invertor board.Try tapping screen lightly,if it comes on the problem is dry solder on Invertor board.
Provide feedbacj and rate this solution.
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Yahoo Messenger Logo
142 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
