Washer not draining
How do I remove the front panel of a GE profile washer to see if something is clogged, as the washer stopped draining, but still agitates?
  • 3 more comments
  • zchurchz Mar 31, 2008
    I had a repair man come out shortly after we got this washer because it wouldn't drain, he removed the bottom faceplate and showed me the trap that you can unscrew and empty...this wasn't in the manuel anywhere, so I didn't even realize the faceplate was removable, he looked thru the manuel and couldn't find anything either.Now after every load I have to unscrew the trap at the bottom and drain a gush of water that will not drain on it's own. If this is not done we have a terrible odor on the clothes within a couple of hours and they have to be re-washed!
    Even if it is done right away the water still has an odor to it. because this has to be done constantly we have to just leave the faceplate off at the bottom of the washer. Luckily the washer is close to a drain in the floor so I have to let the water just gush out and go down the drain. Ridiculous! I hate this washer!
    MC
  • Anonymous May 28, 2008
    Same problem...
  • sh3ll3y Aug 21, 2008
    My machine is still aggitating but stops. It won't drain or spin. It is out of warranty and was wondering if it is worth getting fixed.
  • Anonymous Mar 30, 2014
    I need to remove the agitator in my GE hydrowave washer
    how to remove agitator in a ge hydrowave washer
    Sergeant:
    Champion:
  • 262 Answers
On this machine use a putty knife slide the knife across the top slot between top and front on each end you will fell a place where it will stop pull knife out a little and then push in with knife while pulling out on front the front will come off in your hands and every thing is right there
Posted on Dec 21, 2007
Water will not drain from washer
I have had this problem before on my GE Arora front loader. Just remove the lower front panel. There if its like mine there should be a cap and you unscrew the cap. It will start to drain the water so make sure that there is something to catch all the water. There is a lot of water. Then after all the water has drained, remove anything that is clogging the drain. Small socks, pens, pocket trash is usually the problem. Then return the cap to the original position and your done.
Nov 17, 2012 | GE WSXH208A Front Load Washer
Ge profile front-load washer not draining
Firstly took the bottom front panel off and removed the drain plug/trap. Then the problem should be solved easily. For More information please visit Clothes Dryer Element .
Sep 22, 2012 | GE White Profile Series 15 Frontload...
My washer wont pump water out hose is not blocked
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please back for any further assistance.
Daniel
Nov 26, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile model WPRE6100 only spins slow....
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Oct 02, 2010 | GE Profile WPRE6100G Top Load Washer
    GE top load washer will not advance to drain and spin
    Apr 15, 2010 | GE Profile WPRE6100G Top Load Washer
    I have a GE Harmony top loader washer all digital. My washer will not drain throught the drain hose. I have to lower the hose to the floor for the water to come out any ideas
    Your pump might have something in it. I got a shoestring out of one the other day. Remove the front panel and inspect the pump.c8963d3.jpgbottom right of the photo is that clogged pump, The top does not pop up. The front panel comes off.
    Mar 17, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
    GE Profile Washer WPSR3120W2WW agitates but won't drain/spin
    Your drain line is more than likely plugged with a sock or something of that nature.
    Aug 11, 2009 | Washing Machines
    GE Profile washer will not drain. (DOES SPIN)
    take the front off the washer take the two hoses off the pump youll probably find where its stopped up
    Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
    Clogged washer pump
    you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
    Apr 05, 2008 | GE WBSR3140DW Top Load Washer
    Fixing a clogged pump on GE Profile washer
    Take a putty knife and slide it in between the front panel and top to pop the clips that hold on the top. Remove the front panel and you will see the pump down in the front corner. Remove the hoses (watch for water) and you should see any clog. Check hoses and drain line (home) to be sure there is no clog in those while you have it apart. Be sure to unplug your machine before working on it as well. Good Luck!!! Jim
    Sep 09, 2007 | GE Profile Prodigy WPSE4200A
    Washing Machines Logo
    293 people viewed this question
    Top Washing Machines Experts
