Question about HP LaserJet 2500 Printer
My hp 2500 printer will not print. caution light and half circle light is lit up won't go off. I just change the ink toner with a generic toner.
  • 90 Answers
SOURCE: How can I see how much toner/ink is left over?
You can get the user guide here: http://h10032.www1.hp.com/ctg/Manual/c00264334.pdf
This should help you determine how to tell how much toner is left.
Posted on Dec 11, 2008
  • 52 Answers
SOURCE: HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Posted on Mar 06, 2009
jagesar
  • 9 Answers
SOURCE: New HP CP2025 printer prints "ghost" DVD circles between labels
hi, i work for a company who is the dealar of hp products.
you have to do a clean service of your hp printer.
after that the printer should not have ghost print any more.
Posted on Apr 17, 2009
  • 214 Answers
SOURCE: Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Posted on Apr 23, 2009
JackHeath
  • 1049 Answers
SOURCE: My printer worked very well until I changed the
Smeared output can result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing parts, this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner or you can clean the rollers with rubbing alcohol.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
Finally, if this does not resolve your issue then make sure the fuser is heating; toner that is not heated properly will fall from the page and smear. If the thermostat is bad or the fuser not working properly, you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
Posted on May 12, 2010
I changed the toner cartridge and now it won't print. The red round light on the control panel is lit. Now what?
If the round red light you describe is a circle of dots that indicates a developer change is due. This needs to be done by a technician but the machine should work fine without doing the developer change.
Nov 10, 2017 | Sharp AL 1631 Copier
What do symbols on top mean?
Welcome to Fixya
Half circle symbol means printer is in ready state. The printer control panel is comprised of six lights and two buttons. The lights produce patterns that identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Thank you for using Fixya!
Feb 08, 2011 | HP LaserJet P2015dn Printer
How to change cartridge
Step one: Prepare the print cartridge CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print cartridge with a sheet of paper. Follow these steps to make sure the new print cartridge is ready to install into the product.
  1. Remove the new print cartridge from the packaging. Gently rock the print cartridge from front to back to distribute the toner evenly. c00382111.gif CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  2. Pull the tab and remove all the tape from the print cartridge. Put the tab in the print cartridge box to return for recycling. c00382112.gif
Step two: Open the product
  1. Make sure you have turned the product on. Press the Power button if it is not lit.
  2. Open the print cartridge access door, and then wait until the carriage is idle and silent.
  3. Remove the old print cartridge. See the recycling information inside the print cartridge box. c00382110.gif
    NOTE: If you cannot remove or install the cartridges even though the power is on, check the product control-panel display for error messages. If none appear, turn off the power and then turn it back on.
Step three: Replace the old print cartridge
  1. Insert the new print cartridge in the product. Make sure the print cartridge is in position. c00382113.gif
  2. Close the print cartridge door.
CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric .
Nov 07, 2010 | HP Hewlett Packard LaserJet 1022 Printer
Printer Problem-Not printing at all.
Half circle = ready to print (when light is on )
! mark in a triangle = Attention light : Indicates printer media input tray is empty, print cartridge door is open, print cartridge is missing, or other errors. See Printer information pages for more information.
( light on means that there's an error )
piled circles = toner indicator (light on means toner ("ink") is low, needs replacement)
There's a help page for these light indicators, just in case other lights are / come on, see:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?cc=US&lang=en&objectID=c00230632&prodSeriesId=410622&prodTypeId=18972
Control Panel light indicators overview:
Jul 23, 2010 | HP LaserJet 1320 Printer
I have a bunch of hp 1300 printers. new q2613x
Perform the steps given below to clean the cartridges manually
=== Manually clean the ink cartridge and the contacts on the printer ===
1. Turn on the power to the unit and raise the cartridge access cover.
The cartridges will move towards the center.
2. After the carriage (the cartridge holder) stops, unplug the power
cord from the back of the unit. This will keep the cartridges from
moving back to the capping station.
3. Remove the cartridge(s) from the carriage.
4. Using a soft, clean, lint-free cloth or a cotton swab lightly
moistened with distilled, filtered, or bottled water gently clean
the face, edges and the electrical contacts. (Change to a clean
cotton swab as needed).
CAUTION: Be careful not to touch the ink nozzles on the bottom of
the print.
5. Inside the All-in-One, clean the contacts in the print carriage
with a slightly dampened soft, clean, lint-free cloth. Allow the
electrical contacts to dry completely.
now check if the issue still persists.
May 20, 2010 | HP Printer Cartridges (Complete List): ,...
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
Printer not printing documents sent to it
Your talking about the LED with a horseshoe Icon. This LED should be green and it means the printer is ready to print if this the only LED lit.
If this LED is flashing, it means its processing some print job or is printing something.
Nov 24, 2008 | HP LaserJet P2015dn Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
Sep 08, 2008 | HP LaserJet P2015dn Printer
HP Color LaserJet 2550n
Are you using generic toners or HP branded? Try to reseat the yellow toner. The page counter can't be reset and should not be. This unit uses chips to recognize the toner level. Generic toners don't always have good chips on them.
Jul 09, 2008 | Office Equipment & Supplies
HP LaserJet 2500 Printer Logo
237 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
