Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
I have a Sony 42" Grand Wega. I think my lamp need to be changed. I look at the book guide, unscrew at the bottom back, but the cover seem to be jammed in the middle. Do I have to do something sprecial without breaking it ?
    Guru:
  • 1,326 Answers
If its jammed there is a screw, nothing else holds them on. Look very carefully as none of these tv's have a snap on back. They usually have screws all around the side and some where the coax/video inputs are then sometimes one or 2 hidden places. Look were the resistance is, o can bet there is one that may be somewhat hidden.
Posted on Oct 02, 2009
Lamp light is blinking on my sony 42 grand wega rear production tv...how do you fix install a new lamp
first step.remove the screw and lamp door cover at the right side of your TV . After removing the screw and lamp door cover, you will see the lamp cover (it is color black with a handle at the bottom).then turn the knob/handle of the lamp cover on counter clockwise direction to remove it. Then you will see the lamp of your projection TV. Remove the old lamp and replace it with a new one..Make sure that the lamp is properly installed, the return the lamp cover and turn the knob on clockwise direction to lock it up,then return the cover ,screw and its done...
Sep 18, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Can i order a new lamp cover piece for my sony
Call Encompass Parts Distrubtion or Look it up online at their website
1-800-638-3328.
Dec 27, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lost the lamp cover, changed light and tv wont come on
the lamp cover has a small tab that pushes the lamp switch..the tv will not turn on without..you need it :))
Dec 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How to install the replacement lamp in my Sony Grand Wega KDF-42WE655?
Two thumbscrews on either side of the tv on the lower part on the back(reach around the back on either side and you will feel them), unscrew them and the lower front panel will pop off. It will take a little tugging to get it to pop off but you will hear popping noise. then toward the center there will be another cover with a thumbscrew unscrew this and remove the cover, the bulb is located under this cover, then use the provided Allen wrench and unscrew the two Allen wrench screws holding the bulb in. Next insert the new bulb making sure you push the connector in firmly. Then re-assemble the unit.
Oct 10, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replace bulb sony KF-60XBR800
When you are in front of tv grasp the right side of the front grill and pull it off, the lamp door is right behind it. Unscrew the cover and remove it, you will need the allen wrench provided with the new lamp to remove the old lamp just unscrew it and pull it out.
Sep 15, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
REPLACED LAMP WITH XL2400 AS REQUIRED
3 time blink shows that Lamp Cover is not fixed properly. Please check Lamp Cover and make sure its fixed securely.
Mar 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42 in won't turn on
You can remove the lamp and look directly to the lamp and Anode. Check to see if the Anode busted or the Glass outside of the lamp if it seem to Cloudy. In that case you have a bad lamp.
Becareful with lamp door ,it has a safety switch.
Dec 31, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
See owner / operator manual...if not available,can be downloaded
from our website....................T.
Feb 21, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
12 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
