Need sky remote code for lg model rz-42px11 - Televison & Video
4 Suggested Answers
thewylds2
  • 10 Answers
SOURCE: Need a code so that i can operate my LG tv. model
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Posted on Apr 25, 2010
SOURCE: TV SETUP CODE
you could try the blink back method as described on the following link?
http://www.satcure.co.uk/tech/digicode.htm
cheers
Neil
Posted on Dec 18, 2007
SOURCE: sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
Posted on Dec 28, 2010
What is sky remote code for LG 42LB5500
It depends on the Rev. number of your remote. Older Sky remotes are programmes for different models compare to new ones.
A surerfire way to set this up is to use the Sky "Program my Remote" feature from the Sky box itself (it's in the Help menus), or direct from the Sky web page: http://sky.uebv.com/ Each way will ask you to chec k the revision (rev) number from the sticker inside the battery compartment.
Sky com Find your remote control code
Sep 07, 2014 | LG Televison & Video
Sky remote code for lg 42LD450 42
May 24, 2010 | LG 42LD450 42 in TV
I need the code to program my sky plus remote to my new lg tv it is an lg 42pq300
press intreactive on sky remote move down to sky costomer service press select then move down to program remote ( 5 ) you will need make ( lg ) and model number of tv then follow on screen instructions
hope this helps
Nov 28, 2009 | LG 42PQ30 42 in. Plasma TV
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
Aug 29, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
42LH3000 I CANT GET MY SKY REMOTE TO WORK WITH THIS TV. I NEED A CODE IF THERE IS ONE
To use sky+ remote control with LG 42LH3000 you must have a rev ver8 remote controller.
The codes are stored in a database of the Sky remote. If the old codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Version 1: August 1998
Version 2: December 1999
Once you have the ver 8 controller - code 1176 should work
Aug 11, 2009 | LG 42LG30 42 in. LCD HDTV
Remote to opperate sky volume
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 17, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Looking for manual for RZ42PX11
Hey,
your manual is available on this page
http://safemanuals.com/user-guide-instructions-owner-manual/LG/RZ-42PX11-_D
Let me know if you need anything eldse.
Thanks,
Ekse
Feb 17, 2009 | LG Televison & Video
Sky remote code
0206 usually works for LG
Let me know if any success
Feb 07, 2009 | LG RZ-15LA66 15 in. LCD Television
Sky remote code for LG 42LC46 tv
After spending hours on this I found that code 0206 worked on my sky+ remote(with LG 42LC46). On an old sky remote, prior to version 4 (inside the battery compartment), just use 206.
This code was actually for a LG 42PX5D but it works perfectly on my tv.
Jan 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
HD READY
Im thinking this set will need an hd adaptor as you need at least 1081i resolution for hdtv.
Apr 04, 2006 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Televison & Video Logo
181 people viewed this question
Top Televison & Video Experts
Electro Med Services...
