Question about Wurlitzer Jukebox CD Player
Rowe CD 100 err 05-62
I've got a Rowe CD-100. Was working fine for a while.
Started intermittenly stopping and just spinning the CD really fast. A reboot of the system fixed this usually.
Now, when the unit is turned on, the CCC, and Mech controler flash "Board Error" and the mech doesn't even move.
I looked in the error history, and it comes up as err 05-62 CDM communication error. I have a service manual, and it points to power not getting to decoder, or bad mech.
I since then, bought a decoder/mech controler (from ebay), and installed it. Still same problem.
A friend of mine had a complete spare mech sitting in his garage. I borrowed it, installed it. Same problem.
I pulled the power supply for the juke out, and verfied every pin was putting out the correct voltage. I verfied the mech was getting the correct volages. Still, same problem.
Just for giggles, I unplugged the rowe communication and power plug from the OBA, same problem.
Has anyone run into this problem before? Am I barking up the wrong tree with looking at the mech? Starting to pull my hair out on this one.
  • mrjcain Aug 11, 2008
    I have the same problem but mine doesn't do it every time but it still wont play my box is a cd100 c
  • sarahelms_03 Oct 08, 2008
    Our jukebox does this same thing. If anyone has any ideas that might make it work, PLEASE let me know.
Have a cd100c and a check sum error comes up anyone know what it is
Posted on Feb 02, 2010
The laser is probally getting weak. replace the cd player.
Posted on Apr 24, 2009
    Scholar:
  • 195 Answers
I know you say you have checked the power supply for the voltages, did you do that with the jukebox still connected if not it could be that the voltages are breaking down under load.
The way I test the PSU's on jukeboxes is to check them under load (on the bench I use 12 volt and 24-28 volt volt lamps)
I would check the voltages at the service switch to make sure that the service switch is not your problem.
I would reset all the error codes and check for new errors.
Regards
Alan Hood
ami-man
UK
Posted on Mar 02, 2009
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
I've had my jukebox for 6 years and the free play ran out. I forgot the code its a rowe cd 100 commerical
it should have a free credit button on thecircuit board they usually black or
red just press several times
Aug 21, 2011 | Wurlitzer Jukebox CD Player
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
My rowe cd 100 sometimes doesnt play the cd and it spins it back
Clean the laser eye with a cotton bud. Otherwise it is probably a laser unit problem.
Oct 21, 2009 | Wurlitzer Jukebox CD Player
Err message on 1999 Jeep Grand Cherokee 10 CD changer
I had a similar problem which responded to the use of a CD cleaner disc to clean the laser lens reading the CD. The "err" messages stopped and the changer started to work as it had before. Perhaps this will correct your problem too.
Aug 02, 2009 | Jeep AM/FM Cassette with CD Changer...
Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Rowe CD-100-C Jukebox
Yes you will require a replacement CD player.
If you are in the USA then Bruce Wentworth is your man.
Bruce Wentworth
A&B Jukebox Repair
56 Old County Rd.
Plaistow NH 03865
Tel: 603-382-6272
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
Nov 25, 2008 | Wurlitzer Jukebox CD Player
CD Player stopped working
Probably there is dust on the lens. My CD player (different brand) did the same. I opened the case and cleaned the lens with a photo camera brush (VERY gently). Now it works fine.
If you cannot / do not want to open the device to access the lens, you may want to buy a cleaning CD.
Aug 01, 2008 | Coby CXCD395 Shelf System
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
1,374 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
