Question about Maytag Neptune MAH5500B Front Load Washer
Lights come on, timer works but machine doesn't actually come on
    President:
  • 1,304 Answers
Motor control unit
Posted on Oct 05, 2009
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Ge washing machine timer plastic clips broke
go to the manufactures website and request this clip from them or go to a scrap yard and look for the same machine to take the part out of it to replace yours eric
Dec 27, 2017 | GE Washing Machines
I connected my timer according to instructions but the timer doesn't move.
Timer is not identified:
1) Add a comment with clear description of timer for possible help, and include photo of timer posted on flickr. Also include what steps you took to connect timer, including voltage, wire colors, type of Load (light, fan, motor) being controlled.
2) Question posted under Woods 83660 timer.
The timer doesn't 'move'
83660 timer plugs into outlet, and then selector-dial is manually rotated to set options.
3) Open following link to help identify timer, and then add a comment for possible help.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
Aug 14, 2011 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
Apr 25, 2011 | Hardware & Accessories
2001 Acura maintenance light is flashing after I changed the oil. How do I reset it? Also, my blower stopped working on the heat.?
I can answer the FIRST question.
A. Car is off.
B. With car off, hold down BOTH trip buttons that are to the right of the tach.
C. Start car while STILL holding the buttons down.
D. Hold buttons down until they stop blinking THEN RELEASE THEM BOTH.
Done!
Note: That Maint.Req'd light is nothing more than a "timer". It doesn't mean anything. It is supposed to go off to remind you to change oil, etc but doesn't actually measure anything.
Nov 21, 2010 | 2001 Acura 3.2TL
Timer is set properly, but, the daytime lights never switch off
The timer doesn't know what time it is until you set current time.
The yellow outlets are controlled for 12 hours, and you can determine when those hours occur when setting current time.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
If you want timer to control one lamp with both day and night schedules, you have to adjust current time setting so lamp schedule falls within a 12 hour period. If that schedule doesn't fit, then buy a second timer.
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
Aug 07, 2009 | Coralife Zilla Aqualight Power Center
Maytag Neptune MAH5500B Front Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
