Question about HP Officejet 7210 All-In-One InkJet Printer
When faxing, a 1, 2 or 5+ page fax goes fine but a 3 or 4 page fax does not go through? I have a 7210 All In One machine.
    Scholar:
  • 92 Answers
Recheck your settings, much like you would when printing something.
There ia a default setting that it will automatically revert to b4 every use and will automatically send on that setting.
Be sure the setting match what job it is you are doing at the time.
Consult the manual on how to configure your settings.
Posted on Oct 02, 2009
I need to reprint the last inoming fax. HELP!!!
Printing a Fax in Memory If you have Fax Storage ON for remote retrieval, you can still print a fax in the memory when you are at your machine: 1 Press Menu/Set, 8, 4. 2 Press Fax Start. 3 Press Stop/Exit. (See Turning On Fax Storage, page R-2.) Polling For details about the Polling feature, call our Brother fax-back system 1-800-521-2846 (in USA), 1-800-681-9838 (in Canada) and request at the Index. (See Features That Are Not in the Manual, page 6-6 for details.) Polling is the process of retrieving faxes from another fax machine. You can use your fax machine to "poll" other machines, or you can have someone poll your machine. All parties involved in polling need to set up their fax machines to accommodate polling. When someone polls your machine to receive a fax, they pay for the call; if you poll someone's fax machine to receive a fax, you pay for the call. (See Canceling a Scheduled Job, page 6-5.) Some fax machines do not respond to the Polling feature.
Jun 24, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
The fax was working fine this morning, then I replaced an ink cartridge, did the alignment page, test page, they all seemed to work and now I can't get faxes, on the opposite end it just rings or goes to a...
I guess you should have the auto answer button turned off in the process of replacing the cartridges, turn on the auto answer and you should be all set
Jun 14, 2010 | HP 1050 Plain Paper Inkjet Fax
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
Received pages are cut off
This problem sounds like you have a NOISY or DIGITAL phone line. Press the MONITOR key and listen to the dialtone. It should sound static-free
Your fax machine needs a dedicated ANALOG phone line for optimum performance.
Jun 09, 2009 | Panasonic PANAFAX UF-6000 Fax
Black streaks on prints
Where the original page that you wish scanned/faxed there will be a device called a "scan part". This device "reads" the paper to be faxed/scanned as it passes. It usually is found very near where the paper to be faxed goes in.
If there is a spec of debris on this part it will cause a fine line straight down the document. If its dirty, the document will be too! Just give it a good cleaning and you should be fine.
Did this help? Click "FixYa" below!
Thanks
Len
May 29, 2009 | Brother IntelliFAX 4100 Laser Fax
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Faxes only top of page center is blank
change your resolution from fine to super fine and make a copy to verify your fax machine"s scanner operation.
Mar 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Trouble sending fax from 1 machine when 2 fax machines are on the same line.
I am not an expert but I would suggest to simply diconnect the other one when sending cheeeeeeeeers
Feb 13, 2007 | Brother FAX-8070P Plain Paper Laser
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
HP Officejet 7210 All-In-One InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
