Question about Brother HL-4040CN Laser Printer
Fuser error I have a fuser erro r what can I do
  • 215 Answers
Fuser basically MELTS the toner onto the paper permanently. It is a critcal part of the printer, it is a 'replace' job rather than 'repair'.
and also this is NOT something you can fix by yourself.
hope this may help you
Thank you
Posted on Oct 02, 2009
I have hp 9500 but it show me 50.6 fuser erro I change the fuser it still the same
Please read through these troubleshooting steps and suggested repairs: http://www.laserquipt.com/support/idx/46/292/article/-50x-Errors.html
Apr 17, 2015 | HP Office Equipment & Supplies
Error fatal 928 how to fixe it
Error 928: Fuser Motor Lock Error An error was detected with Fuser Motor rotation by overload. If rebooting the machine does not improve the symptom, you need to check the Fuser Unit.
Sep 09, 2014 | Oki Data Americas, Inc. OKI C 711n -...
Canon iRC5185i with the erro code E000007-0201 . i need the solution to clear this erro
Manual:
E007-0201 Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
I can't understand what it means.
Oct 25, 2013 | Canon irc5185i
50.1fuser erro hp5550dn
50.1 Fuser error:Low/No Fuser tempatrature, replace Fuser assembly.
For service engineers: Reason: thermo switch open, remove fuser assembly, dis-assemble up sleeve, check switch continuity, if no continuity, remove switch & just hit gently on aluminum capsule till continuity comes,make sure it should not damage or dent,once continuity comes, clean main thermister & sub thermister, fix it back, power on the printer, chek errors,adjust fuser temperature in low, give prints up to 50 blank copies, chk.. if problem repeated replace Fuser assembly, but success rate is 70% for above exercise. Note: Only professionals can perform this activity..
Thermo switch:
Oct 02, 2013 | HP LaserJet 5550 Printer
Last week canon R2018 showing erroe code E007, so we turned it off and on and it worked........for one week and has gone back to showing erroe code E007
u have to replace the fixing film of the fuser unit as this error is caused by that. so u have to get it replaced by a tech .
Sep 23, 2011 | Office Equipment & Supplies
Erro 50.7 da hp 4015
50.7 error is a problem with the pressure release mechanism for the fuser. This is the device that backs up the fuser to aid in removing paper jams. I would remove the fuser, and reinstall. to remove the fuser, turn the printer around so you are facing the back. Drop the back door down and then press on the left side where the door pivots. Slip the door out and you will see 2 blue handles on the fuser, squeeze these while pulling out on the fuser.
May 31, 2011 | HP LaserJet P4015 Printer
We got erro E000
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
it all relates to fuser temp. change the fuser unit.
Sep 29, 2009 | Canon imageCLASS D880 All-In-One Laser...
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
Brother HL-4040CN Laser Printer Logo
142 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
