Question about Maytag MBR2562HES Stainless Steel Bottom Freezer Refrigerator
I need to reverse the Door? - Maytag MBR2562HES Stainless Steel Bottom Freezer Refrigerator
  • 10,865 Answers
Ok you will need a putty knife and a phillips head screw driver [size number two]. Look at the hinges. You will first remove the door from the hinges by unscrewing each screw. this is generally a two person job due to the weight. After you have the door removed look at the side where there are no hinges and you will see plastic buttons in the spots where the hinges will be attached. Pop off those buttons with the putty knife and save them.
Next unscrew the hinge and move it over, turning it upside down. Put the buttons on the side where the hinges used to be.
finally reattach the door.................DONE.
Posted on Oct 02, 2009
How do you reverse the door
If its a side by side like the one showing on your post, I doubt you can unless there is a spot showing for under the door, and the water and electrical lines are long enough to switch.
Mar 28, 2016 | Refrigerators
Can I reverse the door swing on a Frigidaire LTF2140ES0 washer
Thank you for your inquiry, Sterling Calhoun!
From the information you have provided you would like to reverse the door swing on your Frigidaire washer. I have reviewed the manuals for your washer and I was unable to locate any directions on reversing the door. If you need any further assistance please feel free to reconnect. -Matt
Feb 26, 2015 | Frigidaire Washing Machines
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Aug 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My Craftsman 1/2 Hp garage door opener doesn't stop going down despite (quite forcefully!) applying pressure in the opposite direction. It would buckle (and did) if I don't let it continue unhindered...do...
YOU NEED TO ADJUST THE DOWN FORCE.
YOU WANT TO TURN IT COUNTER CLOCKWISE TO THE STOP (THIS ADJUSTMENT IS ONLY ABOUT 3/4 TURN FROM MIN. TO MAX.). THEN TRY THE DOOR IF IT REVERSES TURN IT ABOUT 1/16TH TURN CLOCKWISE. CONTINUE THIS VERY MINOR INCRAMENT ADJUSTMENT UNTIL THE DOOR CLOSES WITHOUT REVERSING. THEN GO 1/16TH TURN FURTHER.
YOU SHOULD BE ABLE TO STOP THE DOOR AND REVERSE IT BY GRABBING THE BOTTOM OF THE DOOR AS IT GOES DOWN AND LIFTING SLIGHTLY. IF YOU CAN'T GET THE DOOR TO BOTH CLOSE AND REVERSE WITH MODERATE PRESSURE YOU MAY NEED ADJUSTMENT TO THE DOOR / SPRING / ETC.
- I DO NOT RECOMMEND ADJUSTING THE DOOR YOURSELF - CALL IN A PRO FOR THAT.
IF THE ADJUSTMENT IS SUCCESFUL ADJUST THE OPEN SENSITIVITY / FORCE IN THE SAME MANNER.
HOPE THIS HELPS
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you reverse swing on door
Ity is not normlly possible to reverse the door on automatic washers, as they are not configured for this.
Tthankyou.
Dec 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
Need to replace my Maytag the door is reverseable. Who makes those now?
The doors are reversabe they go from left hand open to right hand open. Just reverse the hinges, put the door fillers ( triangle shape go toward the front. Remove the plug put it in the other sidel. Now take the metal door strke and put it on the other side, Then take the filler from on side and put it on the other side. Takes 10 to 15 minutes to make the change.
No need to purchase another door!
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does the reversal kit consist of
As far as I know there isn't any "kit" needed to switch a door. It's just a matter of taking out a bunch of screws, reversing some door parts, and putting it all back together. Here's a link that shows how to do it for one model which is typical:
http://www.maytag.co.uk/Assets/U&C_MDE3706AGW.pdf
About all you need is a phillips-head driver and maybe a small putty knife to pry out the filler plugs from the holes you'll be using.
Feb 21, 2009 | Maytag PYE2300AY Electric Dryer
Need to reverse dryer door on Model #FEFB9200ESO
instructions are available here
thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | LG WM-2277HW Front Load Washer
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag MBR2562HES Stainless Steel Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
