Question about Microsoft Xbox 360 Console
Console will not read disc
All well until a couple of days ago - then every time I put a disc in it says Reading then Open Disc... I open it and it says Close Disc.... I do, then after Reading...it just says Open Disc again......!!!!! Help
Took the Xbox into a local repairer - changed the Laser. Took an hour and 25 quid.
So all sorted.
Thanks again for the help.
Regards
Posted on Oct 03, 2009
The xbox is on with the green light and everything seems to be working, until you put a disk into the tray and it says reading then open tray, it makes no noise as though it is not spinning
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Click here to download repair guide...if u need
Dec 28, 2010 | Microsoft Xbox 360 Console
Open trey
You need to replace your disc drive. It is either not spinning correctly or not reading it correctly.
Jan 18, 2010 | Microsoft Xbox Console
Disc reading problem
use a disc based lens cleaner. opening your xbox console will void your warranty.
Aug 20, 2009 | Microsoft Xbox 360 Console
Dryerdryer
THE UNIT SHOULD HAVE TWO THERMAL DISCS TO SENCE THE HEAT TEMPERATURE ONE IS THE NORMAL TEMP DISC AND THE OTHER IS A HIGH LIMIT WHICH STOP THE UNIT FROM OVER HEATING. IF YOU HAVE A TEST METER SET IT TO OHMS AND DISCONECT THE UNITS POWER SUPPLY PULL THE WIRES FROM THE DISC ONE DISC AT A TIME AND CHECK TO SEE IF THE DISC IS IN THE CLOSED POSSITION YOU SHOUL GET A READING ON THE METER ON BOTH DISCS IF YOU DON'T GET A READING ON ONE OR THE OTHER REPLACE THE DISC THAT IS OPEN
Aug 09, 2009 | Dryers
PS2 HELP WANTED!!!!!!!
my friend had the same problem what he had to do was keep opening and closing the disc tray untill the 'reading disc' shows up and stays up but he got really anoyed with doing this so he got a new one shortly after this the ps3 came out...
Jun 17, 2009 | Sony PlayStation 2 Slimline Console
READING DISC OPEN TRAY!!!!
I took a small coffee straw and put some liquid silicone in it and stuck it through the front disc tray carefully to the small engine in the back. Hold your finger over the back of the straw so that the liquid stays in until you are over the engine top.Then I put in a disc cleaning disc for about 10 sec and then put in saints row 2 and it hasn't said "open tray" for about two weeks and counting.....
Mar 28, 2009 | Microsoft Xbox 360 Console
Laser is not reading disc says "open tray" after 2 sec. xbox 360
my xbox 360 elite has 2 red lights, which im led to believe is over heating, but it had only run for 15 seconds so cant of overheated so whats the problem? regards paul.
Jan 16, 2009 | Microsoft Xbox 360 Console
Not reading cds.
Now.. if it's four red rings, check your component cables, unplug them, then plug them back in, if it's only three lights flashing with the top-right quadrant remaining idle, then there is a problem with your hard drive and you have to send it in for repairs.. but as far as the fact that it won't play any games, try to get a disc that will clean the eye of the console something like "Maxell" player cleaner, that usually works.. if that doesn't help.. sorry
Jun 08, 2008 | Microsoft Xbox 360 Console
Problem with disc reader
the motor that drives the laser is broke solution get a new drive or motor
May 04, 2008 | Microsoft Xbox 360 Console
Disc reading error
Open the Case.
Clean the lens with Q-tip and Alcohol. This is only if you have the SCPH-30000 through 5000X models. If you have the Slim Ps2 do not use Alcohol on the lens. Use Glass cleaner instead.
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
