Question about Cuisinart Coffeemakers
In the middle of brewing this morning, it simply went dark. No lights. No clock. No brewing. The outlet is working normally.
  • 25 Answers
I will assume you already checked the breaker so lets try this ... unplug the unit,dump all the water/coffee out . take screws out to gain access to the interior .. look at the 2 wire coming into the unit, you will see a small silver thing that is an over temperature safety on one of the wires. (sometimes it is attached to the unit itself ) but it is still inline with one incoming wire. Odds are that is what is keeping the power off.
If that is the problem then you could have a serious safety issue .. or perhaps just a bad thermal switch. It is almost impossible to know which one it is without the proper testing equipment
Posted on Oct 02, 2009
I have a Mr. Coffee, Model JWX20 with no instructions. I would like to set it so that it will come on in the morning and brew coffee before I wake up. I can't find a manual. Does anyone know how...
Set the Clock: 1. Plug the power cord into a standard electrical outlet . The clock will flash on the control panel to indicate that the time has not been set yet. 2. Press and hold the HOUR and MINUTE buttons until you reach the current time. The AM or PM indicator will light a t the bottom of the display The clock is now set! NOTE: Pressing any button before setting the clock will cause the clock to start keeping time from 12:00 a.m. You must set the clock if you want to use the Delay Brew feature. To Set the Delay Brew Time: *While the display is in the clock mode, simply press the SET DELAY button and, while the DELAY BREW time is flashing, set the brew time by pressing the HOUR and MINUTE but tons. *The AM or PM indicator will light at the bottom of the clock display. *Within a few seconds the display will change to the current time. The Delay Brew Time is now set!
Jan 18, 2015 | Coffee Makers & Espresso Machines
Vienna Black suddently stopped working. No lights or anything.
the grinding noises are worrisome. Sounds to me as though something was in the wrong place, and once it worked for one cycle, whatever was left inside, or ??? would have frozen the unit. Sounds to me like you'll need to take it completely apart, to see what's causing the lock up situation.
Jun 01, 2008 | Saeco Vienna Espresso Machine
Cuisinart dgb900bc. Set timer to brew at 5 45. Have for many years. Last two nights at 5 45 clock goes to 12 00 AM. Does not come on automatically. Turn on manually and brews coffee as great as usual....
I would assume that the chip/timer unit has failed in the unit. Not sure you want to try to disassemble the coffee maker to get at it. Have you tried reversing the a.m. to p.m. (thus the clock would read 5:45 p.m. at 5:45 a.m.) settings and seeing if the machine would brew the coffee normally? (although I seriously doubt this will work, but...)
Jun 21, 2014 | Coffee Makers & Espresso Machines
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
reach the current time. The PM indicator will light on the left
of the display.
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Switch doesn't work - can't get it to brew anything
Try unpluging for a few minutes . If that doesnt work try moving to a diffrent outlet . If that still doesnt work . It is time to get a new coffee maker or to call them and get it replaced under warrenty .
This is a known problem with this brand , we have been through 5 of them for the same thing .
It could be caused from anything such as wear (depending on how often you brew) to a power surge that went through your line or even a failure ...
Sep 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Model DE755B coffeemaker
I jst bought this coffee maker,this is the third one,the other two I returned to the store. How can I get it set on regular time to stay?? It flips around to military time and the auto doesn't come on when set for morning. Please help, I have called to get brushed off,now I'm getting angry.I had one beofre that I used for three year until the burner went out.
Please email me at:
gayedjones@embarqmail.com
Jan 12, 2008 | Black & Decker (050876530606)
Won't brew
bring white vinegar to a boil and pour it into the perforated top, the water reservoir and the link between the water reservoir and the brew basket. let sit a few minutes, pour it out and do it again.
put the water reservoir back in, put water and vinegar solution ( half and half) in. Try to start it again. Mine did this last year and this fixed it right away. Try to clean the coffee maker using the vinegar solution once a month to avoid this problem.
Sep 13, 2007 | DeLonghi DCM485 Coffee Maker
Cuisinart Coffeemakers Logo
127 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
