Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 washer problem. F11 flashes at the spin cycle
Kenmore HE3 washer problem. F11 flashes at the spin cycle and machine stops. Do I need to replace (which) part?
This does not happen with every load which makes me wonder if it is just a loose connection.
Perhaps it is a part I can order and replace myself, saving costly service charges.
    Scholar:
  • 31 Answers
If this is showing up as an intermitten problem, chances are that it is just a loose connection.
The F11 code indicates a Serial Communication Error. In english this means that there is a problem communicating with your CCU (the main computer for your washer) and the MCU (the motor control unit).
First remove the top panel (3 torx screws along the top of the back of the washer. If you don't have a torx 15 bit a 1/4 inch nut driver will do the tick)
The CCU is the large white box with all the wires connected to it. It will be on the right hand side of the washer. Check all the connections here first. If everything seems in order then check the MCU next.
To check the MCU, remove the kick panel on the bottom of the front of the washer. Again this is 3 torx head screws holding this on.
The MCU is located on the left hand side right against the side panel. It's white in colour. The connectors will be underneath a little flap (just push it up, there is nothing that is clipped to it). Check these connections.
If you have not found a loose connection your best bet is to call for service. At this point it'll be either the MCU that's failed or the CCU. Without doing certain tests to it it's impossible to know which one.
Good luck! Please let me know if this was helpful!
Posted on Oct 03, 2009
Testimonial: "Thanks. I never knew about the MCU being underneath the washer. I'll reconnect those connections also."
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    No spin cycle
    Suspect there is heavy load in the spin cycle which makes it trip off. You need to check the free movement of the drum and also the motor.
    Nov 20, 2013 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Tub stopped draining /no spin cycle.
    Here is a tip that I wrote a bout front load washer spinning and draining problems...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    May 16, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Cylce stops after 1st drain before spin out
    I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
    Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
    Help! Mt Kenmore Elite Quietpak2 HE3 keeps
    F/06 Drive Motor Tachometer Error
    The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
    • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
    • Check the Drive Motor
    • Check the MCU
    • Check the Wire Harness
    Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Washer won't spin- flashing "f 02"
    in the HE3 series it means the drain tube or pump is clogged
    Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
    Getting F11 code r8ght after starting,then flashes and stops
    usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
    Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
    Error Code for Kenmore HE3
    The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
    Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    180 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Squire
