Question about Intel DG31PR Motherboard
4 G memory not supported - Intel DG31PR Motherboard
  • 38 Answers
This could be becouse your motherboard cant support so mach memory. this could be becouse youve buyed wrong memory that your motherboard cant support. what is your motherboard model?
Posted on Oct 02, 2009
Memory support
  1. 2 DIMM memory slots (supports up to 2GB memory)
  2. Supports 1.8V DDR DIMM
  3. Supports DDR2 533/400 DIMM
Note2: Use of a Double-Sided memory module (the single chip is 512 Mbit) is required if you wish to install a 1 GB memory module
Only supports one gig per slot...
Mar 21, 2012 | Gigabyte GA-8VM800PMD-775 Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Athlon processor upgrade assistance:
Go to this link:
http://us.msi.com/?func=searchresult&keywords=ms-7025
Select the model motherboard you have and click on the CPU support link, it will show you a list of CPU's that are supported. You have a socket 939 board and AMD CPU's are now AM2, AM2+ and AM3 socket, which are 940 pin. It may be difficult to find a new CPU for your motherboard that is new since they have not been made in awhile.
Feb 09, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
Memory card not support.
Possible reasons:
1. Memory card not formatted.
2. Memory card could be larger than 2GB.
3. Brand of the memory card.
Nokia 6085 uses MicroSD (TransFlash) and it could support up to 2GB. If you're using a memory card that is not formatted or bigger than 2GB, you might get this error "memory card not supported'.
Sometimes, brands does matter. Nokia phones prefer to use Nokia memory cards. So you need to try using different memory card to see if there's a problem with the card or with the card slot on the phone.
Hope I answer your question properly.
Have a great day!
May 30, 2009 | Nokia 6085 Cellular Phone
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Memory type for the acer am5630-u5209a
Acer Aspire-Desktop AM5630-U5209a specs:
Memory Type-----DDR2
Memory Speed---PC2-4200, PC2-5300
Memory Type-----Non-ECC Non Registered
Memory Slots----2
Max Memory Per System--4096MB (4GB)
Max Memory Per Slot-------2048MB (2GB)
Dual Channel Memory Support---Supported
Tri-Channel Memory Support------Not Supported
Install Memory in Pairs--------------Not Required
also check your memory voltages by looking at the different memory voltage settings in your bios, write down the choices of the different voltages supplied by the motherboard for the memory.
Not all memory is created equal. for example, i purchased some high end gaming memory that matched my system specs only to find out it ran at a higher voltage than my motherboard would supply. Post again if you need more help ..
Regards..
Mar 20, 2009 | Acer Computers & Internet
Does ASRock 775i65GV supports DDR2 memory?
No only DDR upto 2GB supported by your motherboard...
Dec 08, 2008 | Asrock 775i65GV Motherboard
Supported ram speed for MSI 945pl-neo f
Your motherboard MSI 945pl-neo support Supports four unbuffered DIMM of 1.8 Volt DDRII SDRAM.( Supports up to 2GB memory size.
• Supports dual channel DDR2 memory architecture.
• Supports DDR2 533/400 memory interface.)
and Supports Socket 775 for Intel® P4 5XX, 6XX, P4EE, Pentium D 8XX and Celeron D processors.• Intel® 945PL/ ICH7 Chipset
for more nformation see details od your motherboard here:
http://global.msi.com.tw/index.php?func=proddesc&prod_no=227&maincat_no=1
Dec 17, 2007 | Intel Motherboard
Intel DG31PR Motherboard Logo
60 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
