Question about Irons
I have an Digital Advantage iron and it is getting a Err and won't get hot
Get an analog iron
Posted on Oct 02, 2009
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Jan 24, 2015 | Black and Decker USA Applica Black &...
How do you replace the cord and or dismantle a Black and Decker Digital Advantage Iron
have this done by an accredited appliance service shop as it is not a job for beginners.
Feb 19, 2014 | Applica Black And Decker D1500 Digital...
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
I have a black & Decker digital advantage iron. it is about a year old and when I plug it in it beeps and comes up with err or. Can you tell me what is wrong or what i can do
Hi!
I really hope someone can come up with an answer to your problem.
Personally, I have an iron, and a toaster, and a toaster oven with the old-fashioned dial where the degrees of heat are approximately displayed.
I had them for decades it seems, and I've never had to suffer any fallout from either ironing my shirts at plus or minus 5 degrees from the digitally recommended temperatures, nor from toast that was slightly darker one day and lighter the next.
I'm not a caveman, just in case you wonder. I do have a microwave oven with a dial timer as the only variable, and I must say on its behalf that it has served me without a hiccup the dozen times I used it to either warm my tea, or help defrost the odd TV dinner, which ended being cooked in the toaster oven.
In all seriousness however, needlessly digitally controlled appliances just because it's cheaper to manufacture them, don't score highly with me.
Furthermore, these electronic circuits appear to have a predetermined and highly predictable life expectancy, and oftentimes the appliances they control are cheaper to replace than to repair.
Feb 14, 2011 | Black & Decker Irons
The Clean light on my Black & Decker Digital Advantage iron has come on and I can't find my manual. How do I 1) clean it and 2) get the light to turn off?
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Jan 12, 2010 | Black & Decker D2030 Iron
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
I have a Digital Advantage iron, the cleaning prompt comes on and I don't know what to do, thank you
I think you need to fill the water chamber almost to full, plug the iron in and rotate the steam dial all the way to the left. There is a "clean" setting. The iron will splutter and drip water and produce steam. This is the cleaning process. You can probably have the iron on any settinng. I hope this helps.
Jun 26, 2008 | Rowenta Professional DX8800 Iron
How I can fix The Black&Decker digital advantage that does not heat
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Feb 16, 2008 | Black & Decker AS150 Iron
Irons Logo
55 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
