Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
How to replace a home HVAC thermostat? - Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
  • 70 Answers
Look at the wires on circuit board and match the same color wires to the lettered terminals on the t-stat
Posted on Oct 04, 2009
What is the other slider button used for? How do I set the differential +/-
Setting thermostat differential to 3 degrees? - HVAC-Talk
hvac-talk.com/vbb/showthread.php?...Setting-thermostat-differential-to...
Dec 27, 2006 - 12 posts - ‎5 authors We set both the differentials on the thermostat to 3 degrees. ... very low, but I doadmit to changing the differentials to 1 degree on the thermostat ... How does an adjustable temperature differential work?
Apr 5, 2011
Honeywell Thermostat TH8000 Series
Jun 27, 2009
Honeywell Thermostat Cycle Time
Feb 3, 2005
More results from hvac-talk.com
Oct 16, 2015 | Heating & Cooling
Trying to find model number on a robertshaw thermostat
Why? There are many thermostats available which simply need to match the system you are using to heat and cool your home. I recommend the most basic thermostat that will do the job rather than any of the complex digital ones, each of which have their unique programming methods which read like a geek manual. Just be certain that the wiring that connects the thermostat to the HVAC system is done properly. In most cases, simpler is better.
Nov 14, 2014 | Heating & Cooling
How to turn hunter thermastat model 44134 on
This question needs to be reclassified with aftermarket programmable home thermostats--not fans.
Hunter 44134
Getting the wiring connections correct to the terminals in the back plate is essential. Understanding better which colored wires do what functions for your particular brand and model of HVAC gear proves essential, too: "That's the rub!"
Unlike the brilliant and wisely-instituted electrical code, a sensible common "code" for HVAC thermostat wires doesn't exist--each brand, and many models represented by such brands--may have their own peculiar wiring color conventions. HVAC techs also have noted the increasing numbers of brands and models in the market these days, as well--thus, they too may resort to online help threads concerning such issues. (Certainly, the wiring conventions for heat pumps differs also from that of a conventional heat/air setup.)
Unfortunately, many of Youtube's demonstrations from HVAC pros prove merely general info concerning HVAC systems--these may prove somewhat useful: Being merely general info, they're often not specific enough always for particular units, though. (This proves keenly true concerning thermostat wiring.)
Always switch off the circuit breaker for your HVAC system before proceeding with wiring. My system is a Goodman heat pump--it uses a five-wire thermostat setup: The 44134 model from Hunter doesn't feature a terminal in the back plate for the "C" wire for that. (The blue wire from my Goodman heat pump is the "Comm" or "C" wire--that's very confusing in it's own way--the "B" terminal on the back plate for the 44134, and most other programmable thermostats, often is used with B-coded wires for other manufacturers' HVAC units--generally, "B" wires for such units are blue, as well--beware of reliance upon wiring colors!)
Hunter's FAQs clearly indicate that the "C" wire connection isn't always necessary, nor appropriate, for their thermostats--their 44134 is one isn't an exception. I twisted on a small, gray wirenut onto end of my blue Comm wire, further securing that better with electrical tape. (Simply wrapping the Comm wire well with electrical tape should prove also sufficient.)
Unless you know your system's peculiar wiring very well (that is, you're likely an HVAC tech), don't try to connect a Comm wire to another terminal on the back plate for the 44134--you'll likely ruin your thermostat (perhaps along with some other HVAC electronics): You may need then to get an HVAC tech out, after all!
As indicated above, don't merely "match" wiring colors (as a woman might for interior decorating or remodeling)!: This proves a continuing and overly common, comical mistake! Prove instead somewhat skeptical of thermostat wiring colors! A Biblical scripture applies: "Be as wise as serpents!" Take your time to get wiring connections right!
I've noted that the 44134 unit relies totally upon 2 AA batteries (not supplied in the package)--those must be in good working order and oriented correctly--otherwise, your thermostat and HVAC system won't function. Furthermore, the control unit may be easily removed from the back plate--thus allowing "easy-chair" configuration--again, HVAC and fan functions will halt immediately--the connected unit proves necessary for continued function.
Hunter also points out (on their packaging as well) that the 44134 (and, many other (if not all) Hunter thermostats) won't work with baseboard heating systems. Hunter's site FAQs prove too sparse--some may prove keenly useful, nonetheless.
I can't yet get my heat pump system to work with Hunter's "always on" fan switch setting--the rightmost "Auto/On" setting for that bottom-mounted switch at the right. Perhaps a jumper wire proves necessary in the back plate terminals--somewhere. (I've noted this also for Hunter's common 44277 model, as well.) I glean perhaps that somehow invoking the "G" terminal proves necessary. As usual, investigation proves warranted.
Definitely note the "Cool, Off, Heat" switch on the bottom left of the unit: Yeah, that's all too easy to forget. The Hunter 44134 doesn't provide any feature allowing automatic switching between heating and cooling--one must choose which function for the thermostat to control. If the switch is set to "Heat," cooling isn't possible--and, vice-versa.
For reference and troubleshooting, keep the manual and install instructions in a safe, memorable, and easily accessible place. Hunter does provide PDF manual versions online--installation instructions prove lacking online though--they're not in the user manual, either. Unfortunately, Hunter doesn't upgrade it's PDF manual versions.
I glean that Honeywell units may prove generally more easily configurable than Hunter units. Nonetheless, configuring Hunter units proves far from impossible, though. Configuring Hunter thermostats prove perhaps not as "intuitive.": The formal user manuals provided by Hunter thus may prove more keenly necessary for their thermostats' configuration.
Getting personal help online from Hunter may prove somewhat difficult (that may have changed recently). A few years ago, I called customer support: A woman answered my wiring question very satisfactorily. (I noted a jumper wire connect to the terminals of my old manual thermostat--she indicated that the jumper proves unnecessary in Hunter units.) Hunter phone support hours prove somewhat limited--they're similar to traditional office hours.
As with most programmable thermostats, the Hunter is a PRC (Chinese)-fabricated general-purpose consumer circuitry device. As such, it's (overly) intended to be wired and configured by the user to provide correct function for many particular and compatible HVAC brands/models. Given the particular installation that may perhaps prove difficult. Given the general-purpose nature of such thermostats, a simple installation sheet of instructions can't always offer sufficient and correct answers.
Without the particulars of your HVAC system and thermostat wiring, it proves very difficult in some cases for Fixya and other DIY sites to provide correct answers. (Most DIYers ultimately do succeed with install and use of programmable thermostats, though.)
"Proust" thanks you for getting this far!: Perhaps some of my particular solutions here do prove useful to some of you--more nit-picking, detailed work and anecdotes (intended for specific brands and models) needs to be offered in this area....
Mar 17, 2013 | Dryers
What are some examples of home automation?
HVAC, centralized control of lighting, automatic security systems, applicances, etc
Jan 30, 2013 | Home Automation
White rodgers hvac not working
Hi. This is Aaron Moratalla from White Rodgers. We need to verify your thermostat model number and its settings. It would be best for you to call our Tech Line at 800-284-2925 so we can get more technical information. Thank you for choosing White Rodgers!
Dec 26, 2012 | Honeywell Programmable Thermostat Heater
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
Hi I have a 2004 Envoy, my service check engine light came on so I had my mechanic check it out and we found out that there was a problem with my thermostat not reading correctly and it was causing my...
During the thermostat replacement your mechanic probably had to disconnect the battery. When reconnecting the battery, the HVAC system may not have recalibrated itself properly, or one (or more) of the doors (or its actuators) may have become stuck. Try the following; place all the HVAC switches and controls to their OFF or CCW positions, disconnect the battery for about a minute, then reconnect the battery. Do not touch any of the HVAC controls for at least 2 -3 minutes. If this procedure does not resolve the vent issue, you will need to have the HVAC system diagnosed.
Jul 19, 2011 | 2004 GMC Envoy
Frigidair HVAC not cooling; Believe its a emergency heat problem
the switch is on your thermostat - look for something that says "system" or "Em heat, heat, off, cool" switch it to "cool" and enjoy. If that doesn't work, call a HVAC service tech. You could have bigger problems than just the system switch. Good luck
Sep 05, 2009 | Frigidaire FAS185N2 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
