Question about Kodak EasyShare Printer Dock Series 3
My EasyShare printer dock series 3 only prints the bottom of pics
My EasyShare printer dock series 3 only prints the bottom half of the picture. I changed the color cartridge and it still does the exact same thing.
IB4G2008
  • 3587 Answers
SOURCE: Kodak EasyShare Printer dock prints bottom half of picture
does this happen with the test page, too?
Posted on Feb 27, 2008
  • 36 Answers
SOURCE: Only half of picture is printing
Kodak sent me an email that said I need to reflash the firmware
I will post if that helps
MM64
Posted on Apr 02, 2008
  • 31 Answers
SOURCE: Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
  • 3 Answers
SOURCE: Paper Jam / Printer Dock Series 3
try this no promises
unplug the power cord for 5 sec
paper should feed out after resetting
DONT EVER PULL ON THE PAGE WITHOUT THE MACHINE EXITING IT FIRST. THE TABS ON THE END OF THE PAPER BREAKS OFF INSIDE THE PRINTER DOCK.
check the back of the dock for the photo to eject as well as the front.
check paper size with new one after it exits to make sure no extra pieces are stuck in printer. good luck
DONT PULL ON PAGE JAM (UNPLUG FIRST(RESETS THE PAGE OUT THE BACK/FRONT))
Posted on Apr 22, 2009
  • 119 Answers
SOURCE: I have a Kodak Easy
Does the test print also print only half of the printer? If so, give Kodak a call - bad printer
If the test print works, try changing the usb cable.
Posted on Jul 11, 2009
Kodak easy share printer dock 3
sounds like its only receiving half the data. try these step... uninstall printer from your device... reinstall printer to device... if youre using a smartphone or tablet, switch to a pc... press and hold the cancel button on the printer... turn it off for 60 seconds then power it... run the nozzle cleaner function, then try again
Jul 05, 2016 | Kodak EasyShare Printer Dock Series 3
Why is my Easy Share Printer Dock only printing the bottom half of a picture?
I am having the same problem I want an answer i need to do a project for my son for headstart
Sep 09, 2011 | Kodak EasyShare Printer Dock Series 3
Printouts are missing top/bottom half of picture. Tried replacing cartridge and/or paper but to no avail.
make sure on your program that you are using to print your pictures, that you have the correct photo size. You could have it set for like a 4X6 for an example, where you might need a 5X7
Apr 18, 2011 | Kodak EasyShare Printer Dock Series 3
Printing Issue
It has dust or built-up goo on the feed switch. Try some canned air
Jun 11, 2010 | Kodak EasyShare Printer Dock Series 3
My easyshare series dock 3 only prints the bottom half of the photo ?
clean the printer ink cartridges- that sounds like its an actual circuit board issue with the printer however
clean with rubbing alcohol and q tips
Aug 06, 2009 | Kodak EasyShare Thermal Photo Printer
Kodak easyshare printer dock 3 prints only the bottom half ?
maybe the settings are set to print a picture on paper that's twice as big as the paper you'r eusing? like, if the settings are set for 8x10 paper and you're using 4x5...
that's just my guess.
Aug 04, 2009 | Kodak EasyShare Color Photo Printer Dock
Kodak EASYSHARE Printer Dock
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Kodak EasyShare Printer Dock Series 3 Logo
79 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
