Question about Desa International Comfort Glow Infrared Vent-free Gas Space Heater
My gas valve is not workingon the unit gwn30ta made by desa c # 098522-28 can i replace caN I FIX
  • 139 Answers
Gas valves on desa units are not field serviceable.it must be replaced if defective.
Posted on Oct 03, 2009
Let the gas valve out and unit turns off
get a compressor and a nozzle and blow it out from top to bottom controls pilot and all
Nov 30, 2013 | Desa International Unvented Gas Space...
I need replacement logs for a Desa Model CGFB32CA. No one lists the log numbers, including the manual. Where can I get the item number?
As you probably already know, DESA International is no longer in business. However, depending on the age of your unit, some parts are still available, as is the Owners Manual. The parts for Comfort Glow gas logs (which is what you have. And probably purchased them from Lowe's some years ago) are interchangeable with DESA's Vanguard line.
You can find what you're looking for at www.desatech.com. However, don't be shocked by the price of the replacement logs.
Feb 05, 2011 | Desa International Wall/Window Air...
I have a glo warm heater and when I prime the pilot light it stays lit but when I let up on the knob pilot goes out
haven't had much to do with heater brand but have with pilots it sounds like the thermocouple is either not tightened into valve properly or that it needs replaceing they will burn out over time and usually just a simple replace will fix but you must call service agent if you are not yourself to do this for you as it may be the valve itself which means replaceing that which you must be quakified gas fitter to do even the thermocouple should be done by a competent person as it is a gas heater!
Nov 15, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
My fireplace pilot lite wont stay lite
There is a valve which you are bypassing when you press the pilot button. It is usually a sealed hydralic valve which holds the gas on as long as a flame is on the bulb. This expands the fluid and keeps the gas valve open. If the bulb moved and is not in the flame, or near enough, it will not stay on. Also since it sat for a year the internal workings of the valve could have "gummed" up. You need to replace the valve. You did not mention the name or model of the unit. Do a search with your units brand name followed by heater followed by parts. This should return dealers who can supply the part you need. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 25, 2010 | Desa International Unvented Gas Space...
I have a desa fireplace and it is not working. it is model T36N and would like to know where i can purchase parts to fix it. I live in las vegas nevada zip 89141 thank you
Most parts in gas fireplaces are universal, the valve/thermopile and thermocouple are generic parts and should be found at your local gas fitting supply stores.
If you describe what you tried to fix the fireplace thus far I could give you better advice to which part you need to replace in order to get it running.
Jan 11, 2010 | Desa International Heating & Cooling
Desa unvented propane log heater pilot will not stay lit
check to make sure that the end of the thermocouple is in the flame. This is the hot junction of the thermocouple and it the difference in temp that create the millivolts to operate the gas valve. If it is in the flame, replace it and if a new thermocouple doesnt fix it, you need a new gas valve
Dec 09, 2009 | Desa International Heating & Cooling
I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
CBN30T,DESA, pilot lights, but flames out when the burner comes on.. burner stays on a few seconds and shuts off due to cold thermo-couple. pilot flame seems to jump up and disconnect from the jet, as if...
ONLY ONE OR TWO THINGS AT FAULT.YOU HAVE A BAD THERMOCOUPLE.THIS IS PROBLEM 90% OF TIME AND CHEAPEST REPAIR.IF THIS DOES NOT SOLVE PROBLEM GAS VALVE IS BAD.HOW IT WORKS:THERMOCOUPLE WHEN HEATED WITH PILOT FLAME CREATES ASMAAL ELECRTRCAL SOURCE THAT HOLDS A MGNET OPEN AFTER HOLDING THE PILOT DOWN FOR ABOUT A MIN..THEN TURN GAS VALVE TO OPEN POSITION AND MAGNET WILL HOLD GAS VALVE OPEN.IF GAS VALVE DOES NOT STAY OPEN IT USUALLY INDICATES BAD GAS VALVE
Oct 13, 2009 | Desa International GWP30T Heater
My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most cases.in a small % of time entire pilot assembly needs to be taken apart and cleaned
Jun 25, 2009 | Desa International Unvented Gas Space...
Need instructions to my transmitter
I have the same problem. The company is out of business DESA Heating. I have been unable to find a solution. FMI bought part of DESA but can't get any help there either. 1-866-328-4537
Jan 18, 2009 | Heating & Cooling
Desa International Comfort Glow Infrared Vent-free Gas Space Heater Logo
96 people viewed this question
Top Desa International Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Desa International Pool and Spa Expert? Answer questions, earn points and help others
