Question about Imperial Refrigerators
Hi,i would like to buy a used imperial ref. what
Hi,i would like to buy a used imperial freezer. what is the life expectancy of a well cared for freezer?
  • 1,000 Answers
Its really hard to say, if it is an older model from the mid to early 80's and older, it may last for quite a number of years but is not very energy efficient.
On the other hand, if it is a newer , 1990 and newer, the life span is from 7 to 11 years.
Hope this helps.
Regards,
Posted on Oct 02, 2009
Life expectancy of television
Depending on the type of TV, the longevity can be affected significantly. If your TV is a plasma model, they run very hot and the plasma only lasts about 4-5 years. That is why plasma is no longer being made by any of the major manufacturers. It was state of the art when it came out, but now LED TVs are the standard. They use much less energy, run a lot cooler and last much longer.
Longevity really depends upon the technology used, not always who made it.
May 03, 2017 | Sony BRAVIA Televison & Video
Clogged drain plug whirlpool imperial
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Oct 05, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Hi there. I accidentally left the freezer door ajar overnight (it's a side-by-side) and found in the morning the freezer was dripping water and the refrigerator side was NOT cold anymore. Hard to tell...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
If you need more help go here:
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 20, 2011 | Refrigerators
Our Whirlpool imperial series refrigerator is not staying cold and freezer will not even keep ice frozen.
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 14, 2011 | Whirlpool Refrigerators
Just plugged in and hooked up water on my new refrigerator about 36 hours ago. temperatures are set at 0degrees freezer and 36 degrees refrigerator. Everything is as expected except no ice is being...
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 13, 2011 | Electrolux EI28BS56IS (278 cu ft) Bottom...
The battery for my Asus Z92KM has become very short lived. If I buy a new battery how long could I expect the computer to run? Could I expect to view a movie of 1 to 2 hours on an airplane?
Hi! Battery life depends on how you use your computer. The normal battery life span is 1 year (more or less, again depending how you use the battery) so if your battery is older than a year you should be expecting to purchase a new battery soon.
Jun 09, 2010 | ASUS Z92Km Barebones Notebook PC PC...
My icemaker quit making ice its a whirlpool ref. imperial series with an ultra ease water filtration system
i could bet my left leg that your solenoid coil has died. im guessing its still pumping water and getting cold.
Nov 10, 2009 | Whirlpool Freezers
Freezer and Ref. are warm
i assume this is a frost free type. the fault may well cure itself.
to hasten the process, remove the back panel inside the freezer and you will probably find the pipework frozen up. melt of the ice carefully with a hairdryer making sure you don't heat any stats that are clipped on the pipework
Sep 04, 2008 | Whirlpool GD2SHGX Refrigerator
Refrigerators Logo
261 people viewed this question
Top Imperial Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Imperial Refrigerator Expert? Answer questions, earn points and help others
