Question about Samsung SGH-X650 Cellular Phone
Phone can be switch on,lights on keys are ok but not working
Phjone can be open but keys doesnt function
  • 324 Answers
Keypad may be malfunctioning you need to change the keypad
Posted on Oct 02, 2009
Hi! My friend has got a Jaguar xj6 1997 with a 3.2Litre engine and automatic transmission. It doesnt start. Went to work,worked just fine. Dead later on the same day. Battery ok. Tried jerking the...
i assume your car is@1997 a model/year x300 a common cause of the symptom you have is a corroded/open circuit wiring at a connector or around under the washer bottle filler white connector i think its the ok to start signal from the security/locking module located below trunk fuse box the module can also go faulty. one easy test is to switch ign on if the check engine light goes off with other warning lights. start there fault finding with the wiring etc
Mar 21, 2017 | 1997 Jaguar XJ6
Hi my nokia 3110c...phone whenever...i switch the phone on...the keypad doesnt work..infact it just works a few seconds as the phone is loading..(enough time to unlock the keypad using the security code)...
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad.
You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
Take care.
Oct 07, 2010 | Nokia 3110 Cellular Phone
4.4 02 Range Rover.Blower only functions
it seems most likely it's the Control Panel faulty as this unit is has a common fault
Feb 10, 2010 | 2002 Land Rover Range Rover
Back window doesnt roll down properly when you open the door, so I have to push it down a little before I close it. Also the lock bottom for the windows doesnt work.
dis-connect your battery for 30 seconds to do a switch reset on your window, when you reconnect the batt your window will go down, open and close rear door to check lock functions ok first. close rear door and using key or switch inside car close window fully with out stopping, this should reset the window.
Jan 05, 2010 | 2003 Land Rover Freelander
Remote not working
Dear,
First u need to check the battery and the proper functionality of the electronics of remote.
There is an easy way to get it done.
1. 1st check the battery condition.
2. If it is ok, then put your phone sensor IRLED (the sensor that is infront of remote) near the lens of the camera of you mobile phone, so that u can see the remote sensor through your mobile phone camera into your mobile.
3. Press each botton one by one and see, the light will emit through the sensor of the remote.
4. Check all the buttons, they should emitt light, means that they are ok and remote is working with any frequency.
5. If any button doesn't emitt light then its means that specific button is faulty or having dust in it.
6. If all the above steps have been done and still remote is not able to access the relevant device, then u need code settings but do these initial and important steps before.
Note!!!
You can open the remote and clean the rubber pad inside or buttons, if any button is missing/not functioning.
good luck...
Sep 13, 2009 | Sharp RRMCGA029WJSA Remote Control
Sliding up and down not functioning for Samsung SGH D500
Hi
press menu-settings-ok-phone settings-ok-slide settings-set these to your preferences, If this doesnt work do a reset in settings (#9) check "reset all" if this doesnt work you have a faulty ribbon cable/slide sensor inside your phone, Can be fixed but you need the hands/tools/parts for the job, Hope this helps.
Jun 06, 2009 | Samsung SGH-D500 Cellular Phone
My keypad is crazy,presses keys itself,all func. hav changed.
ok!!! your phone needs some clean coz the your keypad is randomly cant press will right!!!! then there is something on the switch of your phone i think you press it hard thats why the switch is not functioning well!!! that is tjust the problem of your cellphone ok!!!!
May 20, 2009 | Nokia N72 Cellular Phone
Screen gone blank
look first try reset the phone
pls first hard reset like this if it helps PLS RATE ME FIXYA for help !
Master reset
1) *#7370#, then enter 12345 (This is the default security code unless the user has changed it) and then Yes. The phone then wipes all apps and phonebook contacts on the internal memory.
if it doesnt work then try this to hard reset
switching off the phone then press and hold Call key (Green key) + * key + 3 key + power button for a couple of seconds
pls let me know of the results and do raate me well if i helped u
if this doesnt work ur lcd flex cable or lcd itself might be damaged from impact or pressure u have to get it changed
May 17, 2009 | Nokia N73 Cellular Phone
Nokia 6600 Bluetooth, gallery problem.
My nokia 6600 gallery does not load. It shows "opening" and keeps showing the opening message and hangs. The bluetooth. First it said Unable to connect , when i click pair to device it says "system Error". and Now when i click bluetooth it doesnt load options. Other than that the speed of my phone is very slow.
if u have facing this prob. then switch off the phone and then switch on the phone do this procudure 3 times
Dec 07, 2007 | Nokia 6600
Samsung SGH-X650 Cellular Phone Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
