Question about Maytag MDB7100AWB Dishwasher
Maytag dishwasher won't drain after i repaird a leaky gasket
Hello, I have a Maytag mdb7100awb washer. I just repaired the gasket, and then tried the drain function to test. The water went in find, no leak, but now all I hear is a little electrical hum that lasts about 3 seconds and then quits. After about 15 seconds it tries again...assuming that the pump is trying to start. Any ideas on where I went wrong? Some water did come out onto the motor when I took off the discharge hose to help ease the repair.
  • 3 more comments
  • ednpeach Oct 02, 2009
    Actually, it was the tub gasket that I replaced...so yes, I did have to move the motor. Does that change things? :)
    went home for lunch and fiddled with everything. i didn't undo anything when i lifted the motor slightly to get the new gasket on, but i can't guarantee that i didn't loosen something either. all the wires seem to be connected and solid. still get the short humming noise from the motor though. how do i turn the motor? i tried turning from the inside after taking off the spray arm apparatus. didn't work. any more suggestions. thanks for the suggestions so far.
  • ednpeach Oct 03, 2009
    new to this...where is this specific capacitor located. I've taken it apart all the way down to the lower drain impeller, and still not working...still getting the hum for a couple seconds. Guessing that the capacitor is the next thing to check. Just don't know how to do that.
    Thanks for your help so far! :)
    Ed
  • Maytag Master
  • 909 Answers
The issue is almost certainly with the motor. Possibly the wires that were accidentally interrupted, and if not, it is jambed. It has nothing to do with your replacing the door gasket if you never touched the motor. If it is jammed, remove piping attached to flange and loosen until you see the impeller. Rotate the impeller . If it turns easily, problem possibly not motor. Let me know.
Posted on Oct 02, 2009
  • 1 more comment
  • Terence Fourie
    Terence Fourie Oct 02, 2009
    Almost certainly the wires have been reconnected incorrectly. Make sure you have connected the motor capacitor.
  • Terence Fourie
    Once you have access to the motor there is the electrical side and the pump/wash side. At the pump/wash side, remove the fat rubber hose that sits directly over the impeller. Once hose is pulled away, you will see impeller. Try turning impeller with your fingers or spanner or screwdriver until it turns freely. If it does, check capacitor for a possible short circuit. This will also cause humming as the motor cant start if capacitor is faulty.
  • Terence Fourie
    Terence Fourie Oct 03, 2009
    If the capacitor is not attached to the motor by means of a nut, look in the vicinity of the motor for a small white cylinder shaped object. 2 wires will be connected to it. Another alternative that could be done, is remove the power wires to the motor and connect direct voltage onto the motor. If motor spins correctly then, i would then suspect board.(one more thing to consider, do you have a pressure switch controlling water filling or an electronic water pulsator. It detects water coming in via pulses instead of pressure. Often if pulsator is used, this can also create the same result if defective.
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
Mdb7100awb won't drain. Water remains in the bottom of wash compartment
This dishwasher has a auxiliary drain motor on the right hand side. This motor often will get clogged with debris. Pull the unit out and check the drain motor for debris. The pump has three small screws that hold it in place.
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
MAYTAG JET CLEAN DISHWASHER MODEL # MDB7100AWB, WILL NOT RUN THROUGH CLEANING CYCLES, TRICKLES WATER UP FRONT DRAINS VERY BRIEFLY, REPEATS THIS FOR A PERIOD NEVER KICKS INTO THE WASH CYCLE, THEN COMES UP...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 ;';
Aug 24, 2010 | Maytag MDB7100AWB Dishwasher
We have a Maytag Model MDB7100AWB that is leaking from the lower RH corner. We have checked and repositioned the door gasket, and it helps but does not stop the leak. Any other suggestions?
make sure that the door is not hitting the surrounding cabinet or drawers. and check to make sure that the
dishwasher is not pushed to far back in the cabinet which will cause the door face of the dishwasher to hit the front of the cabinets and not seal all the way around,,
Nov 11, 2009 | Maytag MDB7100AWB Dishwasher
Maytag mdb7100awb dishwasher is leaking from the bottom right corner. starts to leak almost immediately upon starting it. I then opened it and found that the entire tub is filled with water, looks like it...
take off the bottom panel there are 4 screws you got take they are 1/4 inch screws  once the panel is off turn on the dishwasher and see where exactly the leak is coming from
Jun 07, 2009 | Maytag MDB7100AWB Dishwasher
Dishwasher purchased 8 years ago, $200 repair 4
For what you pay for dishwashers its normally better to replace them
Apr 24, 2009 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB Dishwasher Logo
351 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
