Question about Rival 5865-W 6.5-Quart Slow Cooker
It wont heat up and all the lights just keep blinking
When we plug in the pot it won't work. None of the buttons do anything, the pot doesnt heat up, and the lights just keep on blinking. We bought the pot a while back but never used it before. This is the first time we've tried using it
    New Friend:
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Posted on Jul 21, 2013
    New Friend:
You might experience a blinking problem if your crock pot is plugged into an extension cord, then the wall. I've had zero blinks when plugged directly into the wall but it started to with an extension cord.
Posted on Dec 25, 2013
  • 625 Answers
Take out the insert and remove the bottom plate. look at all the connections. the blinking light is probably a neon lamp and because of the AC current will blink or appear to flicker a touch. if you have a meter and are not afraid of testing with the power ON, measure the voltage going in and out through the several wires inside.
Posted on Dec 27, 2007
3 lights blinking on my sccpvc709-s
Someone suggested there is moisture under the pot. Use hair dryer to dry it up.
Other suggestion is if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state
The instruction manual does not say anything. But you can find the Crock Pot number to call.
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-crock-pot-Site/Sites-crock-pot-Library/default/v1397907098387/documents/instruction-manuals/SCCPVC709-S_43_38491059.PDF
Apr 20, 2014 | Crock Pots & Slow Cookers
My rival crock pot model 5865 sticker on the heating unit that tells you high/low etc. fell off and now I don't know which position is high or low? Can you help? Can I buy a replacement sticker? H
L to R Round Left Button- Low-High - Warm Two buttons over each other Top - time up, Bottom, Time down Most Right Button - OFF Lights Left - HIGH Center - KEEP WARM Right - LOW
Nov 09, 2012 | Rival 5865-W 6.5-Quart Slow Cooker
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
Rival crock pot smart pot - low, keep warm & hot lights blink and pot will not heat. is there something i can fix or is the pot destined for the garbage truck?
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Aug 08, 2010 | Rival 38601 Smart Pot 6-Quart
I just put some precooked, still warm food in my crockpot. I tried to set the control to warm so I could serve later. Can't get warm to turn on. How can I?
To better diagnose your problem I need more information. Does your crockpot have a light that indicates when your heating element is ON? If so, increase the temp of the crock pot knob to find out if the LED light comes on at all. (you may also wish to make sure the unit is plugged in and the outlet is working properly.)
Since all crockpots work using a temp sensor, it could be that the temp of the food is still warm enough that the crockpot thermostat is not calling for additional heat to maintain the temperature. If you can, remove the crockpot liner and let the unit cool somewhat to allow the thermostat to return to room temp and reset.
If this doesnt solve your problem, chances are that the sensor/thermostat may be faulty or one of the circuits to the heating element may have overheated causing a wire to become disconnected or burn out. Appliances can wear out with use or age and even power surges can 'fry' delicate circuitry.
May 18, 2009 | Rival 38601 Smart Pot 6-Quart
How do I get both 8 hours time and high setting on this crockpot?
I got it on high for 1 hour and then reset it to low for 7 more hours and everything appears to be fine. I suspect that this crock pot runs at a little higher temperature. The *low* setting seems as hot as my older crockpot on high...... With this crock pot - set the hours while turned off with the right button and then turn it on. You may have to play with it several times to get the proper heat setting. As I said, I could only keep on it *high* for 1 hour.
Nov 22, 2008 | CorningWare SC60 Slow Cooker
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
Rival 5865-W 6.5-Quart Slow Cooker Logo
5,181 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
