Is the drum stuck in the machine? If so on some Sharp copiers the right side door needs to be opened before you can remove the drum. Also most of the time the toner and developer units need to be removed before the drum can be removed. If the machine wont reach ready then it should display an error message or a red indicator light should be light. We need to know this before we can assist any further.
This sounds like a digital duplicator. if it is, you may have to turn the drum back to home position. Then the green light will come on so you can remove the drum and investigate why it didn't home out. Check for bent parts, loose sensors etc.
Please help me about three DC gear motor which are remove from Brother 5500 copier machine. Only...
(More)
Please help me about three DC gear motor which are remove from Brother 5500 copier machine. Only informations on their box are: brother DC 598701, brother DC 598702, brother 598703. I need information about their voltage , current, rpm, conection, etc.
