Question about Dell Inspiron 9400 Notebook
Running with AC power, my Dell Inspiron 9400 would randomly show the Blue screen. After a few times of rebooting, I could see the Windows logo with horizontal white lines about 1 " long. Eventually the screen went black. Now when I attempt a reboot or power up all I get is a black screen. The laptop is about 4 years old and has been treated well. Is it worth repairing? Thanks bob
    Novelist:
  • 137 Answers
It was a brilliant laptop ever manufactured. check the costing. for the new laptop as well as the warranty pricing. Yes it is worth repairing, if you can manage the cost. becasue extending warranties would be a cheaper option. The LCD needs to be repalced in your case.
Posted on Oct 02, 2009
Testimonial: "Thank you for your prompt response. It is vmuch appreciated. I will look into replacing the LCD screen. Kindest regards."
I have a Dell Studio XPS PC. Recently, my PC monitor screen began to show all sorts of square spots and vertical lines and horizontal lines with a distoration of color and graphics. Now the Windows 7 will...
try starting it in safe mode....you do that by pressing the F5 key before windows starts up.. like right after you turn it on...once your in safe mode do a real good virus scan..i have seen that happen and it was a virus
Aug 15, 2012 | Dell Inspiron 9400 Notebook
Vertical lines have appeared on sony vaio laptop screen
If the liens are coming during Dell logo also means the screen is going.
If these are visible when OS boots up then reinstallation of graphics driver will solve the issue.
Thanks
Jan 01, 2010 | Dell Inspiron 9400 Notebook
When i start my Dell 9400 up and it takes 10 mins to load to windows XP, , when the windows loading screen comes up the FANS go crazy. I then wait till i'm at the desktop at which point i immediately shut...
Your battery HAS to stay in if its not working which means the OS needs the extra power.
If your fans are going crazy then your laptop is overheating!!!
Contact Dell
Dec 30, 2009 | Dell Inspiron 9400 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Dell vostro 1500 screen goes dark
Check the power options to verify that the screen is not powered down after to short a time. It is in the control panel under power options or in a Dell management utility
Sep 03, 2009 | Dell Inspiron 9400 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Inspiron 6000
If you purchased your I6000 after 2005, then it still has the PC Restore option. For Dell system with Windows XP, your can restore your computer to factory settings by pressing CTRL+F11 when you see the page after the big DELL Logo. It's a BLACK SCREEN with a blue bar at the top and it has www.dell.com written in white. Usually this screen will show up in between the DELL Logo and Windows Logo.
Nov 22, 2008 | Dell Inspiron 6000 Notebook
Not a typical backlight issue
Hi!
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
Hope this helps!
Thanks,
Karlox™
Jul 30, 2008 | Dell Inspiron 1150 Notebook
Password diffucolties
did u made thepass word disc???
u can try this also
reboot the computer go to safe mode by tapping on f 8
go to control pan ....then users acct.....and change ur pwd ...
if this doesnt work u need to recover the windows again
Jun 01, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
145 people viewed this question
Alun Cox
