Question about Patton Heating & Cooling
Plug gets very hot after a few hours use. - Patton Heating & Cooling
Return heater to Home Depot.
Posted on Oct 03, 2009
Runs well for half an hour then stops. Have bypassed the fuel line with auxiliary, but this did not hep. Any ideas?
sometimes when they get hot the spark plug or coil will fail. replace the spark plug and try it if that don't work you might want to check on replacing the coil. as they get older with high temperatures the coil and spark plug will fail at high temps. fairly easy to replace.
May 26, 2016 | Garden
Why doesn't it charge?
Probably the battery can't be charged and needs to be replaced
Sep 21, 2015 | Nextbook Premium Series Next7P12
Have a 1991 bonneville le has to sit for a few hours before it will restart
You may need to check fuel pressure after the engine warms up and shuts off. Maybe the fuel pump gets hot and stops. Have you checked for spark after it dies?
Jan 25, 2014 | 1991 Pontiac Bonneville
I was using the Dyson, turned off to empty tank, will not turn on again, I have checked outlet it is ok. Does it have some kind of safety if it gets to hot.Thanks
hi.
there is a thermal fuse built into the motor of all dysons that will cut the power if the motor gets too hot.
when the motor cools down again, the fuse will normally reset itself.
try the hoover again after a few hours and see if it works again.
also change the fuse in the plug to check that that has not blown
Apr 03, 2011 | Dyson Vacuums
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
Hi
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
My RCA big screen tv sound shuts off
This could be several different problems. You could have loose solder joints, bad capacitors, or the aodio ouput IC could be getting hot andf failing and needs to be replaced.
Jan 10, 2010 | RCA P61310 TV
Frige gets hot and makes clicking noises.
Sounds like the compressor is not working very well the clicking is the compressor starter trying to start the compressor. May be low on freon or bad compressor. You can probaly buy one cheaper than fixing this one
Dec 26, 2017 | Haier Refrigerators
Plug gets red hot on A.C. after 1/2 hour running.
Local hardware store would have replacement plugs and yes that would help the situation out. But the problem may lie inside the actual outlet also. So you may want to investigate the problem alittle more unless you have already done so
May 21, 2009 | DeLonghi CF210 Portable Air Conditioner
I dont know how to remove the radiator drain plug on a 98 chevy malibu it looks like a rubber plug I dont want to break it help.
That may not be a drain plug. Look for a large rubber hose going into the bottom of the radiator disconnect that hose have a bucket or something available to catch your fluids so you may re-use it. make sure the car has been off for a few hours very hot and dangerous coolant will come out of radiator.
Apr 24, 2009 | 1998 Oldsmobile Intrigue
Panasonic DVD-S31
have you ot it setting on something warm or hot like a subwoofer to surround sound or on top of a tv even if you had it there before and it worked they get older and cant take heat as well and they get dust built up in them alot of times one freezing or shutting off is getting to hot is it doing it right when you turn it on if so try unplugging it for a few hours then plug it back and try it
Feb 06, 2008 | Panasonic DMR-ES10 DVD Recorder
Heating & Cooling Logo
83 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
